Casting plaster, making buildings, walls, etc. Anyone done it?
    July 2003
Posted by zokissima on Thursday, October 27, 2005 1:58 PM
I have a few dios planned in the next few years ( [:D ) the next few have some sort of wall structure within it. I was wondering how effective it is to use casting plaster to cast walls, entire structures, or whatever, then scribe in the brick detail? What is the most effective way of doing this, or if someone else has a better idea for creating brickwork buildings, please share.
Thanks!
    September 2005
Posted by Fish-Head Aric on Thursday, October 27, 2005 3:58 PM
I would suggest doing heavy look into the model railroad realms for ideas. These guys build entire cities, using just about every form of material you can think of.
~Aric Fisher aric_001@hotmail.com
Posted by Kelly_Zak on Thursday, October 27, 2005 5:15 PM
Hi Zok,
I do quite a bit of casting of plaster for building walls, etc, I usually use the Duplo building blocks for a form, and pour plaster in it and let dry. I usually add some liquid tile grout colorant to my water before adding to the plaster powder, it adds strength to the plaster. Once done, I draw a quick design and go to work. for recessed brickwork in areas where the wall is all plaster I take a flat gouge and scribe out an area, and scribe in the bricks. Here's a couple pics of what I've done...the first is all brick work, and the second is a completely scratched house made from plaster and balsa, you can see the recessed brickwork I was talking about.
Smile [:)]
"There you go with those negative waves again!"
    August 2004
Posted by Thehannaman2 on Thursday, October 27, 2005 7:35 PM
Kelly - Great looking work, man! The Lego/Duplo idea is great. Do you use anyting to reinforced the plaster, i.e. toothpicks, wire?
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
    December 2003
Posted by buff on Thursday, October 27, 2005 8:31 PM
Kelly, in the second pic, is the remaining plaster on the wall added on to the brick wall after you've done the bricks, or is it left over after you've scribed them? Thanks.
On the bench: 1/32 Spit IXc
    January 2003
Posted by gburdon on Thursday, October 27, 2005 9:33 PM
zokissima:
I will be attempting this type of process on the weekend (hopefully, my wife will allow) lol
The process of casting your own buildings, sections etc. etc. is fully described in a book (my wife bought for me bless her little heart) MODEL BUILDINGS MASTERCLASS by Roy Porter. This book covers step by step how to make your own molds and cast sections of buildings etc.
I would strongly suggest picking up a copy. It's a handy little reference to have.
Until you do here is a sample of the "How to" I have learned from its pages.
Form a mold box (I use "acquired" LEGO from my nephews) in the size of the finished panel to be cast.
Line the mold box with plasticene and smooth it out and spread evenly.
Impress into the plasticene the shape of the "brickwork" you want the panel to have. Be sure not to press all the way through.
When finished lightly spray with PAM cooking spray onto the plasticene.
Mix your plaster to a Cream consistency and pour evenly and slowly into the mold
Allow it to harden (when you're tempted to pull it out leave it 15 more minutes)
Remove the panel and take a look at your work. If it doesn't "look" exactly right don't throw it out use is as rubble for another diorama idea.
That's the basics of it, but you really should buy the book. There is alot more information inside that is too long to discuss here.
Best of luck. If you need more information reply to your post and I will be happy to help.
I see that you are in the GTA you might be able to locate a copy of this at the Ajax show this weekend (Check the FSM list of shows here on the website) Or you could try ordering at your local hobby shop or Chapters.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
    January 2003
Posted by gburdon on Thursday, October 27, 2005 10:03 PM
zokissima:
Here is the link to the book I was writing about above.
http://www.chapters.indigo.ca/item.asp?Item=978185915063&Catalog=Books&Ntt=%22roy+porter%22&N=35&Lang=en&Section=books&zxac=1
Cheers:
Gregory
    December 2003
Posted by buff on Thursday, October 27, 2005 10:21 PM
Thanks for the link, Gregory. Looks like a keeper. I wonder if I should get it used...Big Smile [:D]Big Smile [:D]
Posted by Kelly_Zak on Friday, October 28, 2005 12:22 AM
Buff/Hannaman,
thanks for the comments! For the "recessed" brickwork for the second pic, it's real easy. At first the whole building is just one flat surface. I then took a hobby knife, and carved out som jagged lines here and there. Then I took a 6mm wide flat edged hobby knife, and gouged out the area, about 1 or 2 mm deep. Kind of like carving a pumkin. I then started scribing the brick work. For me it's kind of a reverse process, alot of people think/ask the same thing about the buildings, wether or not I scibed all of the brick work, then added a skim coat overtop. When I tell them the process I just explained, they get that "oh crap, why didn't I think of that" look LOL
Gregory, I tried a method similar to what you described, but ended up in disastor. I've really simplified my method, and that's using the big lego blocks to make my form, then put a sheet of was paper over top of a piece of plywood, put the form on top and add my plaster mix. Gently rock back and forth to level everything out, and wait to cure. Once the form has been removed, I usually let cure for a week, as I add tile grout colourant to strengthen the plaster, and it takes a little longer to dry.
When fully cured, I sand all the edges, removng any of the little bumps that are caused by the spaces between the lego blocks. I'll then scrape/sand the top surface to remove any air bubbles and to level out the piece. I then draw what I want on the plaster and take my dremmel tool and carve out the shape. WEAR A MASK while doing this, it gets VERY DUSTY!!!! Then you can start doing brick work or what ever you want. I'm fortunate enough to have a big compound mitre saw with a big blade, so cutting and squaring off the piece is a cinch.
OH, don't throw away any of your cut offs, or for that matter, any left over plast from your initial pour. Save it, and take a hammer to it, and bag it to use for rubble. Hell, I'll just make up a sheet of coloured plaster just to make bags of rubble! Good luck!!
PS - no toothpics or wire to support the plaster, just mix, and pour!
    July 2003
Posted by zokissima on Friday, October 28, 2005 6:59 AM
Thanks for all the input everyone, this is exactly what I was looking for.
gburdon, thanks for the tips, Kelly_Zak, you too. I did think of using Legos to make a mould, so good to see that I won't be far off the mark.
Now, as for making the brickwork, I think I'll stick with the method described by Kelly_Zak, by actually carving out the bricks. We used a lot of plaster in some art classes I took a while ago, and it was quite easy to carve, so this seems like the easier way.
Also, one more question. When making the mould from the Legos, should I put anything between the legos and the plaster, or will I just be able to remove them fine when the plaster is set?
    December 2003
Posted by buff on Friday, October 28, 2005 7:03 AM
Thanks, Kelly. I appreciate the tips.
Posted by Kelly_Zak on Friday, October 28, 2005 9:29 AM
Hi Zok,
you don't have to put a thing inbetween the lego the plaster. The legos are really smooth, so once your plaster has cured for like an hour, you can disassemble the legos, and they'll pop away from the plaster, you'll just have to clean up the edges a bit. Man, dispensing all this info makes me want to go out and do some more casting! LOL
Oh, scribing the bricks is super easy, all I really do is take a ruler and draw the straight lines across the plaster and use the back edge of a hobby knife to scribe. Once done, take a air can or your compressor and blow off the excess, and you're ready for paint! I just recently acquired some old dental scribes from a friend, so I'm itchin to try them out on my next project!
