HELP!! How do I make realistic looking grass??
Posted by Anonymous on Sunday, October 30, 2005 11:41 AM
I have been trying (unsucessfully) to create realistic looking grass for my first dio. I can't seem to find the right material to use. I bought some "grass media" from a local hobby shop, but it looks like Censored [censored]!!
please HELP,
Chris
    October 2003
Posted by rebelreenactor on Sunday, October 30, 2005 12:04 PM
Try static grass from woodland scenics. Works great.
John
Moderator
Posted by Matthew Usher on Sunday, October 30, 2005 1:20 PM
It does indeed. It's designed for model railroads, but it works well in other scales, too.
In the December 2005 issue I have a "Build your first diorama" article that shows how I used it for 1/35 scale groundwork. I hope you'll find it useful.
Matthew Usher @ FineScale Modeler.
Posted by Anonymous on Sunday, October 30, 2005 2:19 PM
I too concur-although as I told Genn on another post: As far as ground work don't forget to check out your spice cabinet or back yard. Oregano makes for great leaves at this scale!
Posted by Anonymous on Sunday, October 30, 2005 2:48 PM
Thanks everyone, I will try it out and let you know how I do.
chris
    September 2005
Posted by Kykeon on Sunday, October 30, 2005 3:12 PM
You can also make taller grass by cutting 3/8" to 1/2" long pieces of sisal or jute rope. Fray apart the fibers and glue in irregular clumps. I then fill in areas around the tall grass with static grass, as well as other plant materials.
Old house painting brushes are good sources of long fibers too.
Posted by Anonymous on Sunday, October 30, 2005 3:29 PM
Don't use astro-turf!!.......Theres a very bad story that backs this up! Boohoo [BH]
    January 2004
Posted by mpmontgomery on Sunday, October 30, 2005 4:51 PM
I am looking forward to reading the article on the first dio. When does the Dec 2005 issue hit the streets?
Do you recommend laying down celluclay as a base first, and then the grass?
If so, do you paint the celluclay before adding the grass, and does the grass need to be painted or is it natural looking enough that you could go without?
Also, what scale does the product mentioned earlier work best for? I am looking for something that would work well in 1/35 scale. Thanks.
    September 2005
Posted by Kykeon on Tuesday, November 1, 2005 1:14 PM
Static grass works well for 1/35th scale, at least for short grass, not so good if you are trying to make something taller, like say a wheat field. Make your groundwork first. If you are using sand or dirt over the celluclay, glue that down first, then add the grass. Most static grass needs to be painted and you need to airbrush it. Do not try to paint it with a brush, although you can highlight it with a brush once you have airbrushed the base coat.
    June 2005
Posted by smokinguns3 on Tuesday, November 1, 2005 2:47 PM
this is what the spice cabnet holds oregano parcley and poultry sesaning heres the link
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=49905
Rob I think i can I think i can
Posted by Anonymous on Saturday, November 5, 2005 10:45 PM
Wait .... your the one who did that part of the article. that helped me a little but i can't find the thing that you put mold or wutever into to make the dioram (all my hobby store has is a mold of rocks, even though i could just get the real ones outside
    July 2003
Posted by zokissima on Wednesday, November 9, 2005 12:21 PM
The groundwork you can buy from the company listed in the artcle, but you can just as easily construct groundwork yourself.
