Water and farm animals.
Posted by Anonymous on Monday, November 14, 2005 6:44 PM
Hi all,
I am wanting to make a river/stream for a 1/72 dio i am making,does anyone know of any way to make water from house hold things? if not can anyone recomend some CHEAP stuff i can buy?.also does anyone know were i can find some 1/72 scale cow's/sheep/horse's?.
cheers in advance, SSpanzer.
Posted by Anonymous on Monday, November 14, 2005 6:49 PM
SS-If your stream is shallow varnish might work-I think white glue would stay a little opaque. For animals i would get some HO train set animals-they are 1/87 scale-but could just look like smaller animals.
Posted by Anonymous on Monday, November 14, 2005 7:06 PM
Cheers trowlfazz,
    February 2016
Posted by duckman on Monday, November 14, 2005 8:15 PM
for water you could use Mono ultra clear silicone its $5 a tube and it does not ubble underneath.
On The Bench:
Revell- 1/72 Messerschmitt Me P1099
Posted by Anonymous on Monday, November 14, 2005 8:31 PM
 cheers duck man, I think i might buy that woodland scenic stuff,can it be put on poloystring  (i think thats how you spell it) or doe s something have to be put on it first?.
cheers  SSpanzer
    February 2016
Posted by duckman on Monday, November 14, 2005 9:29 PM
sspanzer make sure if you deciced to use woodland scenics that you dont get the beeds that you have to melt down i have had very bad experinces with it
make sure the base of the sream bed is pre-painted before you add the water i did that once before and i learnt my lesson!
On The Bench:
Posted by kp80 on Tuesday, November 15, 2005 7:15 AM
Look at the article in Nov 2004 issue of FSM called "Making Waves".  It's a technique, very inexpensive and very forgiving, to make water, using a base of aluminum foil (to make a wavy water surface, painted to look like water) with a heavy overcoat of ModPodge (which looks like the clear water).  ModPodge is a decopage liquid that looks like thin white glue, but dries thick and clear, giving a nice waterlike appearance.  I used this technique on an HO scale layout, and it looks great...and it is cheap and easy!
Posted by Anonymous on Tuesday, November 15, 2005 8:22 PM
Trowlfazz i think i will make a shallow stream does varnish set hard?.
SSpanzer
Posted by Anonymous on Tuesday, November 15, 2005 9:54 PM
SS-varnish does dry hard but needs to be put on in light coats-remember though that it may react with any plastic animals-but you'll be safe with light coats. And stream water isn't blue-it's clear, or muddy. Blue water is usually an indication of deep water or suspended particles. But a stream would not be affected by either.
