Paint colors for Navy Flight Deck
Posted by IBuild148 on Friday, December 9, 2005 10:58 AM
Would anyone out there know what "Model Master" colors I should use on my WW II Navy Flight Deck and color markings. I want to put an F4U-1D Corsair, FEB 1945 on it and need some pointers.
Thanks,
Marc
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
Posted by HeavyArty on Friday, December 9, 2005 6:33 PM
Depends on the carrier, and when and where it was operating.  Paint schemes changed throughout the war and on different ships.  Best bet would be to ask this in the ships forum.
Posted by Anonymous on Friday, December 30, 2005 8:41 AM
i am not very sure about WW2 carrier colors but modern carriers have a deck that's almost identical to model masters "Gunship Gray" although i'm sure it was different back then. hopefully that will help a little.
    June 2004
Posted by Dave DeLang on Friday, December 30, 2005 8:53 AM
Deck blue - Navy shade 20-B. I don't know if Model Master makes it. Colour Coats do. Dark Sea Blue lightened a little bit would be close. They used stain, not paint on the wooden flight deck of US carriers so the color isn't uniform. It looked a little streaky I believe. Actually, I see that Colourcoats makes a color (or should I say, "colour" ;-)) called: "Flight deck stain 21" that is probably exactly what you need. It's available from the site below or from other sources.
 This site: http://www.shipcamouflage.com/ will tell you everything you want to know.
    January 2003
Posted by Jeff Herne on Friday, December 30, 2005 9:01 AM
Carriers in '45 used Flight Deck Stain #21 which started with the ESSEX class as they came into service in 1943. This color when new matched that of 5-0 Ocean Gray. This new stain was also used on the flight decks of INDEPENDENCE class CVLs and CVE classes in 1943 and into 1944. About mid-1944 there was the introduction of #21 Flight Deck stain (revised). This revised stain was (when newly applied) identical to 20B deck Blue (revised) and was a near match in service with the introduction in March 1944 of glossy Sea Blue, a new camouflage color for use on carrier aircraft. When a flight deck was using #21 Flight Deck stain the deck markings would probably have been in yellow.
Model Master Acryl (acrylic) and White Ensign (enamel) make this color. Be sure you get #21 Revised.
Jeff
