Suspention
Suspention
Posted by Anonymous on Tuesday, January 24, 2006 6:53 AM
I am building a diorama witch will include peices suspended in air. I need advice on how I can suspend the kits inside of a glass case with little to no visability of the support.
    August 2005
Posted by EdGrune on Tuesday, January 24, 2006 2:45 PM
do you want the subject visible through 360 degrees in the case, or will you be limiting the viewing angle?
The means may be to limit the field of view by means of a shadow box.  Supports are then strategically placed such that they are hidden behind an object which blocks their view from the front.
    August 2004
Posted by unclesnap on Friday, January 27, 2006 9:07 AM
0621,  i suspend a c-47 skytrain from a glass case using magic line from Revell Magic Flight kit. i glued the line to the wing tips, then to the inside of the case, i used molding around the outside to hide the glue spots on the inside of the case. i had to go to ebay to find the Revell kit, or you could try your local magician shop for magic thread. it will have little or no visability.
