Need Help
Need Help
Posted by Anonymous on Friday, August 1, 2003 3:47 PM
Hey, i was goin to build my first diorama for a 1/32 P-51...and need some help with the material..I was thinking of a [combat scenerio in the spring or summer time...and it has just been refueled and was about to taxi to take off to fight the Lufwaffe]
I was thinking of it being mostly level ground with some dirt and grassy areas...and get a fuel drum and a mechanic.
Please give me as many pointers as you can cause im goin to need all the help i can getWink [;)]
Thnx
Posted by Anonymous on Saturday, August 2, 2003 10:26 AM
Hi there shark
First u should think of location (North Africa,Europe,etc.) Then u should scout around 4 photos and stories on the web.
U could also ask more specific questions on your subject. (I dont really know a lot on aircraft )
Good luck
Keep well
Posted by Anonymous on Saturday, August 2, 2003 12:39 PM
Well i was thinking of it to be in Europe...but what i was wanting to know is the material to use on this scenerio...like what kind material for the ground then what to use for the grass.
Posted by Anonymous on Sunday, August 3, 2003 8:21 PM
What is this Celluclay?? that i hear about.......how is that used and if you were adding wood planks for it to sit on would you put those in b4 the stuff dried?
Posted by Anonymous on Sunday, August 3, 2003 9:51 PM
Celluclay is just a fancy name for Paper Mache. you add water to made it plyable or formable while it is still wet you can add things to it color it, shape it, It good stuff just be sure to seal any wood if you use it as a base.
Posted by Anonymous on Monday, August 4, 2003 11:49 PM
Thanx, ill look into it then
