Armor suspension
Armor suspension
Posted by Anonymous on Friday, June 9, 2006 4:31 PM
Hey all,
     I'm reading Shep Paine's book, and it says to secure a tank to the dio base, you should place a bolt going from the bottom of the tank to the underside of the base. The only question that I have is how to hide this bolt. The tracks will cover the two sides, but you will still be able to see it underneath the front and rear sections of the tank. Is there a better way to achieve this sprung suspension look without the bolt mabye? Many thanks!
    May 2006
Posted by MortarMagnet on Friday, June 9, 2006 11:48 PM
Basically, sew it down with fishing line.  Make a series of alining holes, small holes, and thread it through.  If you don't want to poke holes in the model, you can loop the line around the suspension mounting points.  I once bolt down a sherman and after about a day there was a snap when the suspension proved stronger than the hull.Sad [:(]
Brian
    November 2004
Posted by sasd on Saturday, June 10, 2006 1:48 AM
During the building process spring the suspension in various areas,glue it in place,mount the vehicle in the desired placement on your dio and build up the groundcover to match the sprung suspension,freeze in place with white glue and water mix.
"Battleing Bastards of Bastogne"
Posted by Kelly_Zak on Saturday, June 10, 2006 10:59 AM
Yah, no need to use a bolt...IMHO that's actually a pretty dumb idea. All you really need to do is either just use straight white glue or 5 min epoxy and just plant it to your base. When I do groundwork such as a non street scene, I use tile grout as my "earth", and while it's curing, I just plunk the vehicle right on top, lightly press it in, but not enough to sink it, and once the grout cures, it ain't coming off.
"There you go with those negative waves again!"
    October 2003
Posted by rebelreenactor on Saturday, June 10, 2006 3:31 PM
I agree, White glue works fine. My Pak 40 dio fell about four feet, everything fell off exept the Pak 40 which was secured with white glue.
John
    September 2005
Posted by Kykeon on Monday, June 12, 2006 3:48 PM
As Sasd suggested, The best thing to do is to build the tank to fit the groundwork. Think about how you want to depict the tank and build the basic form of the groundwork to the desired shape. Then build the tank's suspension to fit the contours of the groundwork. Any gaps between the tracks and the groundwork can be filled in after the tank has been test-fitted to it.
Forget the bolt idea. White glue works just fine.
Posted by Anonymous on Monday, June 12, 2006 6:35 PM
Thanks for the advice everyone!
