spent brass?
    May 2003
spent brass?
Posted by kenny_conklin on Wednesday, August 30, 2006 10:47 PM
any tips on how to make spent mg42 shells or any other brass that looks pretty good in 1/35th scale? thanks for the help everyone.
"Rakkasans Lead the Way!"
Posted by ajlafleche on Thursday, August 31, 2006 7:19 AM
The easiest and most economical way is to stretch some sprue, paint it brass and cut it to length.
    June 2005
Posted by MontanaCowboy on Thursday, August 31, 2006 8:26 AM
Or, snip brass wire (from FSM a few months ago) to length (which is actually very short).
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    June 2004
Posted by ewc2003 on Thursday, August 31, 2006 9:21 AM
An 8mm round from an MG 32 was 57mm long or roughly 2.24 inches... so divide by 35 to get the scale size and you're talking about a little piece of brass that is .06 inches in length...so clipping a 1/16 piece of brass wire into a little pile of casings around the feet of the gunner would be possible.... just REALLY small...
Matt ------------------------------------------------- "The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke
Posted by ajlafleche on Thursday, August 31, 2006 1:39 PM
Actually, you'd need brass rod about 0.010 of an inch in diameter. (Micro Mark goes as small as 0.020) 1/16 rod would give you a casing 2 scale inches thick, something closer to a 50 mm shell.
    June 2004
Posted by ewc2003 on Thursday, August 31, 2006 1:58 PM
Gah.. I hate having the right length and being too wide....thanks for the correction... as my math here at work sans a decent scale calculator is rather crude...
Basically, spent 1/35 casings from an MG ANYTHING would be the same as using the stubble from an electric razor and being painted a brass color then... Big Smile [:D]
    May 2003
Posted by kenny_conklin on Thursday, August 31, 2006 10:02 PM
thankyou for all your help guys will be puttingyour suggestions to use
