Barbed wire at Omaha? and wet sand look?
    August 2006
Posted by IanIsBored2000 on Wednesday, October 25, 2006 6:16 PM
Ok two questions here.  First, is was their barbed wire used on Omaha beach.  Yes I know there was tons up by the cliffs and there was bangalore torpedoes and all, but I mean closer to the shore? was there any around all the Czech hedgehog bariicades?  My second question, is how would you make the look of wet sand? just beyond the waters surface, you know, as the wave recedes, the sand imediately in front of it is still darker beacuse it is wet as the wave pulls back and then washes forward again.  Any ideas would be great.  Oh, and while your here, was there any speical poistioning to the Czech hedhogs and other barricades, such as all in a line along the beach? or were they just scattered beacause the Germans had no idea what time the allies would reach the beach, therefore meaning they had no idea how high or low the tide would be at that point in time?  Thanks, Ian
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    April 2005
  • From: I am at play in the fields of the Lord. (Texas)
Posted by m60a3 on Wednesday, October 25, 2006 6:26 PM
 Czech hedgehogs? Do you mean Belgian gates, or was there a czech hedgehog?
                                                               -60
"I lay like a small idea in a vacant mind" - Wm. Least Heat Moon "I am at the center of the earth." - Black Elk My FSM friends are the best.
    August 2006
Posted by IanIsBored2000 on Wednesday, October 25, 2006 7:20 PM
Hmm, I guess there not called czech hedehogs then because what Im thinking of was used absolutely everywhere on Omaha beach.Heres a picture of what I beleive are called Czezh hedgehogs.  Please correct me If i am in any wa wrong.]
    September 2005
Posted by Kykeon on Wednesday, October 25, 2006 7:50 PM
Yes, they are Tschechenigel or Czech Hedgehogs.
There are also Belgian Gates or "Element C", Tetrahedra, Hemmbalk (logs driven into the sand at an angle with A-frame supports, usually topped with a Tellermine or sometimes with saw tooth edges), Schwimmende Balkenmine, (log rafts topped with Tellermines), Minenpahl, (Tellermine topped stakes driven into the sand), Hochphal (high stakes) and a few other types of Panzersperre or Panzerhindernis to be found on the beaches of Normandy. (Although most of these were primarily for use against landing craft, not tanks.)
Here is a diagram of the beach obstacles on Dog Sector of Omaha Beach;
    April 2005
Posted by m60a3 on Wednesday, October 25, 2006 8:15 PM
 Wow, thanks Kykeon. Good info there.
                                       -60
    August 2006
Posted by IanIsBored2000 on Wednesday, October 25, 2006 8:47 PM
Sign - Ditto [#ditto]  Yes, not only very helpful for this question, but also very informative in general, a great reference.  I saw a webpage like that somewhere with tons of maps like that for Omaha beach.  hanks a lot
    June 2006
Posted by SteveM on Thursday, October 26, 2006 5:59 AM
Ian, here's another one that I used for reference:
Hope this helps you out.
SteveM
Steve M.
On the workbench: ginormous Kharkov dio
