preparing a diorama base
    November 2006
Posted by 65 air cav vn on Friday, December 15, 2006 4:34 AM
What is the first step to preparing a wooden diorama base? What is the best type of wood? My dio. will be approximately 25" X 20" just for some wiggle room. My dio. will be a mooring scene containing two ships. Thank You. Hank Support The Troops
    August 2005
Posted by EdGrune on Friday, December 15, 2006 7:18 AM
Do you have any woodworking tools and/or skills?
Arrange your display on a sheet of paper,  then transfer it to the wood before cutting it.   It is easier to cut it smaller - more difficult to cut it bigger.
I think I'd use some plywood 3/8" or 1/2".   Perhaps some MDF.  You may want to band it with some veneer or solid wood to cover the raw edge.   Rout a decorative edge on the banding,  or at least chamfer it to ease the edge & minimize breakout.
Sand, stain or paint, and finish the wood before building the water.   When dry mask the edges to protect them from the application of the diorama material
Build up any land details and rough paint them
Lay in the first base-coat of water.  Imbed the ships and other water-based details.   If your are doing something like Celluclay for the water, paint it.
Lay on washes of colored gloss to make the water up to the desired level.  Go around the ships.  This will tie them into the diorama.   They are now permenantly affixed.   To late to move them.  Lay the water up to the lands edge.
Finish detailing the land and model items
    November 2006
Posted by 65 air cav vn on Friday, December 15, 2006 8:09 AM
Thanks for the info. Hank Support The Troops
Posted by results may vary on Friday, December 15, 2006 6:07 PM
try this link. i found it in this forum and it was very instructional. goes way beyond just the base but it does start at the base. http://www.armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=690&page=1
paul "We are all made of star stuff." - Carl Sagan
    November 2006
Posted by 65 air cav vn on Saturday, December 16, 2006 1:37 PM
Thank You Paul for the site info. Hank, Support The Troops
