More info would be helpful as to size and type.
What I do is build up the general contours with styrofoam. either leftovers from purchases or the type you can get in the floral department of a craft store. Much smaller and easier to store than the insulation above. (But if you have storage and access, that would work, too.) I use Celluclay, a commercial papier mache for ground work. I mix this with an old style model railroad turn,. brown craft paint and white gule with just enough water to make a thick oatmeal thextured paste.
