long blade grass
long blade grass
Posted by Anonymous on Sunday, March 4, 2007 9:07 AM
Hi,
I'm looking to build a few bases (for Warhammer miniaures) depicting a long-stemmed grass bushes among rocks. Does nayone have any suggestions on achieving th long-stem grass look?
The only product i'm familiar with is the woodland scenics long grass, but I don't find it is very realistic (or easy to work with on a 30 mm base)
I welcome any suggestions...
Thanks!
Posted by renarts on Sunday, March 4, 2007 11:16 AM
cisal rope or chord. Fray the ends and trim to spec. You can paint it and dry brush it to give you some nice effects. There are also some nice options found perusing the dried flower sections of craft stores. Several mosses, small flowers and decorative plants make for some nice scale foiliage.
    February 2005
Posted by prowannab on Sunday, March 4, 2007 11:43 AM
i've used the scenic stuff and i thought it turned out pretty good,i used a styrofoam base and then folded the grass in half,then took a small flathead screwdriver and pushed the grass in at the fold,after that i used mustache scissors to trim the extra off.thats how i did it i hope this helps you out.
Patriae Fidus (FAITHFUL TO MY COUNTRY)
    January 2007
Posted by sofasurfer on Sunday, March 4, 2007 1:41 PM
I used cheap garage brushes.
Tons a grass for under a buck!
    January 2006
Posted by PatlaborUnit1 on Sunday, March 4, 2007 2:05 PM
Hi there
I face a similar problem with my minis.  I have used all the typical standby products, including some kind of dried leafy ferm that you buy in big packages in the dried flower aisle at Micheals.
My approach has been to add them together to make the things I want. I have the typical short static grass (never have really mastered that, it just looks like curls of grasslaying flat in the glue. Where is the stand up when you blow on them part coming into this?)
Im including a pic of my Reaper 72MM Anubis using Woodland Scenics tall grass, the dried fern-ish leafy stuff I got at michaels, Static grass, fine sand and wire painted olive green with tan autoflocking added at the end for cattail reeds. If nothing else works youll wind up cutting very fine strips of paper and dying it green either with green watercolor paint or a marker. This often works in larger scales.
HTH
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
Posted by Anonymous on Sunday, March 4, 2007 2:39 PM
that brush idea looks great! unfortunately I need green vegitation - the wheat color will wash out  my minis....
the michaels idea looks good, but i'm arfaid the mini-plants will not withstand wear and tear of day to day gaming :(
    June 2006
Posted by SteveM on Sunday, March 4, 2007 4:12 PM
You might be able to stain the bristles before cutting them off the brush- use different shades of green on different brushes (dip them in paint?). Brush all the paint off, let dry for a few days.
You could also plant unpainted bristles then airbrush, if you have one. If not, semi-dry brush the colors on. For thicker patches, perhaps the first idea would be easiest?
HTH,
Steve
Steve M.
On the workbench: ginormous Kharkov dio
    January 2005
Posted by daveinthehat on Sunday, March 4, 2007 4:47 PM
I have had a really hard time with the Woodland Scenics long grass. I'm sure it works good, I just haven't been able to get it to look right. I like using the cheap paint brushes. I've found that sticking them in paint the color that I want and washing them out stains the brush enough to make it look like grass or weeds.
I drag a bristle through some glue and stick it in the flock kind of grass and it looks like some kind of flowering weed.
    January 2003
Posted by gburdon on Sunday, March 4, 2007 5:16 PM
Dave;
Another alternative that gives you lots of "grass" without needing to "plant" each stalk is taken from an article I read in Military Modeler years ago.
Take a piece of fake fur from a cheap stuffed animal and dye it the colour you require. Then just cut it to fit the base and mount the figure. You can trim the hairs to required height and give it a quick drybrush to vary the colour.
It really looks great. The article was for a diorama of a 1/35 scale Huey dropping a section of infantry into an elephant grass covered field.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
    August 2006
Posted by IanIsBored2000 on Tuesday, March 6, 2007 2:28 PM
Personally I think SteveM has the easiset and cheapest idea. Use the paintbrush idea, and just dip it in diluted green paint, and get most of it off, so its not globby with stuck together bristles, but its "dyed" to the right color.
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
