Diorama Construction question
Posted by Anonymous on Sunday, March 25, 2007 4:34 PM
After seeing so many great dioramas in this section i decided to do my first one.
The base I chose is a simple picture frame with Celluclay as the medium. My question is : Would I apply the Celluclay directly to the frame (base) or should i put a layer of Styrofoam down first ?
 Any help from is, as always, highly apreciated.
    January 2005
Posted by daveinthehat on Sunday, March 25, 2007 5:25 PM
I would put Styrofoam down first. It provides a good base for the Celluclay. It will also allow you to give the ground some shape or form, unless you want it flat. Its easy to poke holes for tress and stuff in the foam too. I've been using Gorilla Glue to attatch foam. It works really good. The only thing to keep in mind is that it expands, which can be good because it's almost like a foam when it expands.
Posted by Anonymous on Sunday, March 25, 2007 6:16 PM
Thanks a bunch for the reply, Dave. That makes alot of sense.
I love Dave Town btw. I can see small hills to work with styrofoam but how did you achieve those beautiful bigger hills ?
 If my diorama turns out even a third as well as your town I'd be a happy camper.
    January 2005
Posted by daveinthehat on Sunday, March 25, 2007 10:59 PM
I make the bigger hills by stacking up the foam. I put a film of glue on the foam and drive big tooth picks through it to hold it while the glue drys.
I took a lot of construction pictures. They might give you some ideas.
http://public.fotki.com/DaveInTheHat/davetown/construction_pictur/
