War of the Rats Dio.
Posted by Anonymous on Wednesday, March 28, 2007 12:53 PM
I just finished reading "The War of the Rats" (I recommend it) which is thje true story of Vasily Zaitzev from "Enemy at the Gates". In one part of the book it mentioned a Geran sniper who had crawled through the escape hatch of a destroyed Russian tank (model of tank not mentioned). The German was sniping from inside the tank. I'm thinking about recreating this scene, but had a few questions.
1. What Russian tanks were used at Stalingrad?
2. What german were fighting at Stalingrad (SS, etc.)?
Also, this is totaly irrelevent, but I'm new to modeling and still can't figure out what you guys mean by seams (as in filling and sanding them)!?! Any visual aid or other help is greatly appreciated!
Thanks,
--Nick--
Posted by espins1 on Wednesday, March 28, 2007 3:52 PM
At Stalingrad, you would have mostly seen early T-34 tanks.  Germans, StuGIIIB, Panzer III and Panzer IV, probably D and E.
The primary German Unit at Stalingrad was the 6th Army, although other units were involved with trying to clear a path for a German breakout.  I would suggest doing a google search on Stalingrad and you'll find all kinds of information.  There are also some excellent books about this epic battle, my favorite being "Stalingrad" by Anthony Beevor.
A seam is the join line between two parts.  When you glue two fuselage halves together, for example, there is a seam where the two parts join together.  Unless it's supposed to have a panel line there you'll want to fill it with putty, super glue or some other material, and sand it smooth so the seam is no longer visible once you apply paint.  Some of the most common places for nasty seams are along fuselage halves, wing roots (where the wing joins the fuselage, those can be particular tough to deal with as there are often complex curves here, and you don't want to get carried away and sand away panel lines that are supposed to be there), along cowlings and lately, with the modular design of many of the new kits, there will be a nasty seam going around the fuselage where the tail section joins the rest of the fuselage.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    January 2007
Posted by IYAAYAS on Saturday, March 31, 2007 7:08 AM
4th Panzer was also a very key participant...
