Information on plaster diorama pieces
    July 2006
Posted by telsono on Friday, May 4, 2007 4:23 PM
I recently acquired some plaster diorama sets and something from the back of my mind came forward.
Do you have to seal the plaster building parts before painting?
If so what is the procedure?
My set came without instruction and I remember having to do something to plaster prior to painting it. Any help would be greatly appreciated.
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    September 2005
Posted by Kykeon on Friday, May 4, 2007 6:39 PM
I've built several plaster buildings and have never bothered sealing them before painting. A sprayed on base coat of paint effectively seals them. Or prime them if you wish. Being plaster, they are porous and would soak up a lot of paint if you were just brush painting them.
    January 2003
Posted by gburdon on Saturday, May 5, 2007 8:56 AM
If you are brush painting these. Mix a very thin mix of white glue, water and a drop of windscreen washer fluid and brush this over the entire surface first. It seals the plaster.
If you are airbrushing you can prime it with a base colour and it will serve the same purpose but it will soak in fairly quick. So you may need a second primer coat.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
    July 2006
Posted by telsono on Monday, May 7, 2007 10:36 AM
Thanks for the replies guys. That's a lot simplier than what I thought I had to do. My memory may be faulty, but I kind of remember half diluted polyurethane sealer. I rather just seal it with a paint primer, easier. From what you state I would think the rattle can of Tamiya fine gray primer would be sufficient.
Mike T.
