Sticky Base Stain
    September 2003
Sticky Base Stain
Posted by KevinCollins on Wednesday, June 13, 2007 8:09 PM
Hi,
I used a stain (the container said it seals too) on a pre-made wood plague. I stained it with two coats…at least two days between coats. The first coat went on nice but the second coat stayed a little tacky and damp for a few weeks now and still is tacky and damp. If I touch it with my finger I can see where my finger was because of the dampness. What did I do wrong and how can I fix it?….Yeah, I could start over with a new base but I want to know what I did so it doesn‘t happen again. If I use this base as is will it mess up my ground work and not take any glue, etc? Someone mentioned that I may have used the stain sitting in the top of the container and didn’t put the brush down deep enough and so it didn’t adhere well to the first coat. They then suggested to add a third coat making sure that the stain was well mixed and taken from the middle or bottom of the container. I thought I mixed it well enough for the two coats I put on, maybe not. Any help would be appreciated.
Thanks,
Kevin
Pray for Surf! Proud sailor (USNR) of IBU 21...NCW Group2
    January 2006
Posted by PatlaborUnit1 on Wednesday, June 13, 2007 9:25 PM
Hi Kevin
I know EXACTLY what you are talking about, I had the very same thing happen with kitchen cabinet doors that I put a coat of poly on. It never did dry right depsite thorough mixing.  After four days in a hot/dry environment (central California, no humidity issues) I put on a second coat  again fully mixed. I believe it was Minwax brand. Anyway, it stayed sticky until I put a coat of paint over it.
Any chance to strip the stuff off and restart? Unless this is a super uber base, I would be tempted to toss it, perhaps get a different stain, thorougly mix and start over.  A third coat may not set either since the second coat may affect it, especially if the solvent is not properly dispersed from that coat.  The groundwork may mix but I'm guessing this is now a mix of gloss and semi gloss which reall does not look that great, plus the fingerprints around the edges.....
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
    June 2006
Posted by SteveM on Friday, June 15, 2007 5:51 AM
Is it one of those deals where you have to sand in between coats? Some brands say not to, but they also don't mention the tackiness.
Steve
Steve M.
On the workbench: ginormous Kharkov dio
