- Member since
Posted by berny13
on Tuesday, October 7, 2003 6:49 PM
QUOTE: Originally posted by rigolosi
II have also seen pics of the ones used in Tan Su Nhut they were older sandbag and block style . |
I was stationed at Tan Son Nhut from '67-'68. The revetments used were the corrigated steel type. Only the 45 th TRS used the old French two sided revetments made of concrete block and steel rods. They were open in the back so corrigated steel was used to close in the back. Over on the Charley ramp, the revetments were PSP parking ramps. There were no revetment walls. After Tet, '68, sandbags were put around the revetments for a short time only. Part of Charley ramp was then built with corrigated steel revetments to house the C-123's and C-47's. The sand bagged area was torn down leaving only the PSP ramp which was used to park the C-7's from the Army. All of this was completed by March, '68.
When working with the F-4 RAM (F-4 Rapid Area Maintenance) support out of Hill AFB from '69-'71, I spent 18 months in SEA. I was on most every base used by the US at one time or another, repairing battle damaged and crash landed aircraft. Almost all bases had the corrigated steel revetments. There were a few of the French revetments left, but they were used only for transient aircraft.
If the base was built by the USAF, it had corrigated steel. If it was left over from the French, it was concrete or concrete and earth. If it was built by the US Army, sandbags, psp and corrigated steel. US Marines and Navy used corrigated steel. British and Australian forces used corrigated steel.
Berny
Phormer Phantom Phixer
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
