Three great diorama's, step by step
    February 2007
Posted by T-rex on Thursday, July 12, 2007 2:19 AM
After waching a DVD called "The Clinic" by Woodland scenic, not just I now know how to do real diorama's but I'm more determine to make some, so I've started on them about a month ago,but now I'm back from seatle and let me show you beginners how to do a diorama the woodland scenic way!
First start with the base, this one is going to be a hill so I've cut cardboard and assemble them to a a four side base, notice the side are the same shape as the hill going to be. Then stuff the inside with newspaper, the cardboard ontop is for extra support.
This one below is the one for my tiger, but for a more harder or spesific shape I use styrofoam, the base is seperatly sold at micheal's, Always apply tape around the base, its gonna be messy.
2end step is to apply plaster cloth of the work piece, always double layer and to help spread it out use a paint brush.
I'm open for comments.
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
    March 2007
Posted by kcmat on Thursday, July 12, 2007 2:57 AM
no pics Confused [%-)]
http://www.myspace.com/madmat77
    February 2007
Posted by T-rex on Thursday, July 12, 2007 8:43 AM
Not again!, man this is killing me, hold on let me try again.
    February 2007
Posted by T-rex on Thursday, July 12, 2007 4:32 PM
Ok, now it work, I'll show the next step later, I'm free to answer any question.
Posted by ajlafleche on Thursday, July 12, 2007 6:16 PM
Kind of early to post any comments.
    November 2006
Posted by ww2modeler on Thursday, July 12, 2007 6:36 PM
Maybe it would have been good to sand the styrofoam down to the desired shape and THEN applied the cloth over it.
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
    February 2007
Posted by T-rex on Thursday, July 12, 2007 8:08 PM
One step ahead of you, sanding it will only make it smaller, and by apply plaster cloth  over, which I did, but thanks for the advise.
Here's a layout for the vehicule in each dio's.
This is where a firfly crew found a dich old wagon that got rolled of the hill.
The tiger scene mit have the kettenkrad with it, and you can see where the puchhend will go.
And here's the third dio for my LTV, its going to have water gel.
And its not too early for comment, in fact its almost too late, I started on these dio, one month ago, but there still not done, thanks.
    November 2006
Posted by ww2modeler on Thursday, July 12, 2007 8:14 PM
The second one looks abit crowded. Maybe take out the Tiger and put a kubelwagen or schwimwagen in there.
David
On the bench:
Posted by Anonymous on Thursday, July 12, 2007 9:54 PM
...interesting...
    July 2003
Posted by Dwight Ta-ala on Thursday, July 12, 2007 11:38 PM
Dioramas are about stories. A good diorama is one that effectively conveys a message or story. So can you give us an idea of the stories behind each scene?
I also suggest that you work on your dioramas one at a time for you to be able to focus your attention and efforts. Moreover, you can use the lessons that you will learn while doing the first to have better results on your second and so on...
    October 2005
Posted by Brumbles on Friday, July 13, 2007 9:18 AM
I second what Dwight said, but I applaud your enthusiasm!  You've come a long way, T-Rex, in just a few months.
    February 2007
Posted by Luftwoller on Friday, July 13, 2007 2:22 PM
Go for it Dwight. You've bigger Cahoonas than me , thats for sure.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    August 2005
Posted by Phil_H on Friday, July 13, 2007 7:22 PM
David
+1
If I were a German tanker, I wouldn't want to drive a Tiger into what looks like a tank trap. Also, look at the placement of your Puppchen. The little notch you've got it in would severely restrict it's field of fire. You also need to remember that it's more than just a single piece - you would need room for a crew to fire it, and some storage space for reloads. Also, keep in mind that this was a short range weapon and the bad guys would have to get within 200 yards before it could be used effectively.
Perhaps it would be better to set this space up as a MG position, or set up a MG position close by to provide covering fire/overwatch.
    February 2007
Posted by T-rex on Friday, July 13, 2007 9:47 PM
thanks guys for the comments, but let me explain, First of all the tiger isn't leaving the scene, I've make that diorama originaly for the tiger, I've added the kettenkrad and the puchhen for more viweing, the puchhen is on a man made hill, that's why its spot doesn't look natural, alsothe tiger isn't moving into the trench, its stoping for resupplie and refuel, I just have place the tank equipement yet, speaking of tank trap, I didn't know the puchhen is more of a close range gun, but it could be a trick for ennemy tank that approche the hill too close, and BAM, they get blow away, and t-34 are too manurable up close. But I'll keep the MG idea, that would be nice.
    November 2006
Posted by ww2modeler on Friday, July 13, 2007 10:16 PM
It just seems that with the addiotion of more stuff, it would seeem very crowded and not look very realistic. Plus, a Tiger would not stop to take on fuel and ammo where combat is still going on. The Soviets would just call in an arty barrage and neautralize the area. And, if it were a front line, I dought the Germans would have had the time to construct a man made hill. This might help.
The Püppchen ("Dolly"), a carriage-mounted rocket launcher with breechblock, fires the same 88-mm rocket that is used with the Ofenrohr. The breech prevents any flash to the rear while firing is in progress. To lower the Püppchen's silhouette, the wheels may be removed and the piece left standing on two sled-like rests. In preliminary positions the ground is dug out so that the horizontal section of the lower carriage and trail will lie below the surface. For an all-around prepared position, circular trenches with an inner radius of about 2 feet are prepared. The barrel is left just clear of cover, as is done in the case of the preliminary positions. The lower carriage is dug in and the trail wedged, so that the piece can be fired at an angle of 180 degrees. Positions are prepared in defilade or on reverse slopes, and are well camouflaged. In general, enemy doctrine governing the preparation of positions and the conduct of fire is similar to that for the Ofenrohr, except that only two projectors of the Püppchen type are considered necessary for satisfactory interlocking fire.
The maximum effective range of the Püppchen is considered to be 220 yards, although badly dispersed fire up to 275 yards is possible. For this reason the Püppchen, like the Ofenrohr, is employed in the foremost infantry positions. For added protection from artillery fire, the launcher may be detached from its carriage and removed to a shelter some distance away from the prepared position. Alternate positions are prepared only when the terrain restricts the field of fire and provides good cover for the maneuvering piece. In such terrain each position is constructed so that the Püppchen can be run in and out on wheels. Since the Püppchen is harder to conceal than the Ofenrohr, the Germans believe that it is necessary to furnish the larger weapon with antitank protection in the form of obstacles, natural or artificial, supplemented by mines. Because the Püppchen's carriage is not strong enough to stand up under motor towing at high speed, and since horse-draft sacrifices valuable time and involves the problem of replacing animal casualties, the Püppchen generally is transported on trucks and is used only in positional warfare.
David
On the bench:
    February 2007
Posted by T-rex on Saturday, July 14, 2007 1:33 AM
3 things I mite change, replace puchhen with MG and maybe replace kettenkrad with a supplie wagon, also there is no combat happening in a scene, in fact its just a tiger returning from a scout/reconising mission looking for enemy tank in august 1942 kursup Russia, its hidding behind a hill for protection since there vurable when refueling, The story in  this scene is the tiger didn't had enought fuelto reach main campso it stop at a small german outpost,the kettenkrad/wagon rendevu with the tiger for resupplie, get it.
The firefly one is a interesting story, august 1944, beligum, a scout fireflyfounds a dicht german vehicule that was abanden and rolled off the cliff to lighted there load, the fireflycrew thinks that it was abandon not long ago, (which is why the commander is scoping the horizon) but it been down there for 4 years.
There no big story about  the ATV, its just going onto the beach in the battle of Iwo jawo, there willbe lots of tank supplie ontop of him and a few in the sand lost in the beache.
Any last comment before the next steps?
Posted by Model Maniac on Sunday, July 15, 2007 4:20 AM
Nice work so far! Styrofoam and plaster cement are the materials used by my modeler to build diorama bases too.
Impressive Songs:
All 10 Playlists that I created on Youtube:
http://www.youtube.com/user/ModelManiacThailand/playlists
Pan Flute Music (300 songs) (Most Popular, over 100K views):
https://www.youtube.com/playlist?list=PLUNb2zPxGTZO7alagEPsEMzgBkWt4-vKV
El Condor Pasa (Top 50) (World's most famous and my most favorite song):
http://www.youtube.com/playlist?list=PLUNb2zPxGTZOLKHbju350mLle4HkMhsb8
    February 2007
Posted by T-rex on Monday, July 16, 2007 10:44 PM
It seem that it the tiger scene that has the most problem chossing the vehicule, but I have some tank and barracade assesories that could be use, and the kettenkrad mit be replace by the flak wagon converded into a suplie wagon. I don't know but the story of the scene is a tiger 1 is stoping for refuel and reload at a small german out post, it would even be better with a bigger artillery or a MG in the nest, but there gonna be some figures around the scene. Kurusk Russian, 1943.
The firefly is a interesting one, this firefly on a road for scout enemy ase, bunker, etc reconnising, has found a broken fence near the road, ontop of the hill, they found a abandond german vehicule, (wagon initaly but kettenkrad would do) that was dich to light the load, the commander thinks that it was form a german convod, but this pieces was left there since 1940, during the german invading france, but this scene willhave the nices landscape of all the other dio's. august 1944, Beligum.
There nothing special about the AVT on, just the vehicule coming onto ground on Iwo Jawo, since large amounts of supplie was lost but the tide, I left some luggage on the sand.
Each scene is a good practice for assesorie, (tiger scene, which I call it "reload") landscape (a old dicht it" and the LTV "land ho" is the first with water gel, which will be hard doing the waves.
3rd step some of my dio's needs rocks, using woodland scenic rock mold (because there very realistique and made of rubber) apply plaster and when its dry, just pull it inside out. There are three main rocks in the fireflt scene, one stick with plaster coverd around the rocks with plaster to make it blend more with the terrain.
To make smaller rock is easy, just take a big piece of dry plaster and break it into pieces, then just apply it around where collables rocks would likely be.
4th step, what's a dio with some earth, apply brown paint or in this case earth undercoat, this is for mud that way If I miss a spot you won't see the plaster cloth, apply senic cement after painting.
5th step I know I should have put the plaster before painting it but I can always repaint, and this is for making mud, espesaly in the  tiger scene man made hill, and to make it look more wheel take a crush piece of paper and tap it in radom spots on the plaster, then roll some lego wheels for track mark's, this make the dio look more realistique than any other step.
 This is the step I'm doing now, the rocks aren't painted yet because I'm not certain that stone grey will be a suitable color for eastern roock, and now I'm starting on foliage and making trees for the firefly scene, but sofar everything looking good.
    February 2007
Posted by T-rex on Friday, July 27, 2007 11:33 AM
Does anyone know how to make trees? Woodland scenic does sell trees but there more idel for 1/72 scale, I've try making some out of plaster cloth, play doh and even real tree branches but they all look fake and realistique.
    June 2006
Posted by ps1scw on Friday, July 27, 2007 3:31 PM
Got the camo on the Tiger yet?  I'm very interested in seeing it.
    February 2007
Posted by T-rex on Sunday, July 29, 2007 2:47 PM
The tiger right now is done with its oven cleaner wash, all of the heavy coats of paint are gone, but it made some pieces fall of, now it has to be repaire.
As for the camo I'm having second thoughts if its gonna put one on the tiger or not, I'm abselutly horrible at doing free hand camo and tamiya has no such color called "forest green" or something near, i'll have to use model master instead. Speaking of camo there are three other models would will also need on, My  LVT 4, a Puma helicopter and my new flakpanzer wriblewind maybe doing camo with tape mit help.
It would be better for the scene that the tiger has a camo pattern but If I keep srewing it up I mit as well scrapt the tank or put him in another scene with a different color like just dark yellow or german grey.
Any comments on the three dio's before moving on.
    November 2006
Posted by ww2modeler on Sunday, July 29, 2007 7:46 PM
Why do camo on the LVT? Most were just a basic one tone green and that will make it easier on you to. What kind of helicopter are you doing, can't give you any help if we don't know the type and country. As for the Tiger, try using silly putty. Or, take some paper and practice painting with the airbrush.
David
On the bench:
    February 2007
Posted by T-rex on Monday, July 30, 2007 11:27 AM
The Iwo jawan LVT had camo on a few but don't worry mine doesn't has camo, it's just olove drap, althought the coulor looks strange on it. The puma helicopter is just another project, but thanks for the silly putty idea, I'll use it on the tiger and the wirbelwind.
Now please let's get back to topic, it's my dio's here!
    June 2006
Posted by ps1scw on Monday, July 30, 2007 12:30 PM
how did the over cleaning wash go?
what color olive green did you use on the vehicle?
Do you have a picture of the helocopter?
    July 2003
Posted by Dwight Ta-ala on Monday, July 30, 2007 11:57 PM
Looks like you are moving along just fine with the base. I just have some comments on the stories (as you have requested) from where you based your dioramas.
Diorama No. 1
From the position of the Firefly, it would be difficult to spot the fallen carriage unless some soldiers on foot were walking along the edge of the road. Also, if the carriage was already there, then it would have looked old and would have been covered by vegetation. With that if ever it will be seen by the tanker or the soldiers, they would easily understand that it was there long long before.
Diorama No. 2
I concur with the other comments that the spot is too tight for the tiger to maneuver into. There is a great risk that the tiger would become trapped and immobilized while moving through those narrow path. Also, the Germans have other vehicles designed specifically for recon that I don't think they would risk having a lone tiger venture into enemy territory for a recon mission.
These are just my observations.
    February 2007
Posted by T-rex on Tuesday, July 31, 2007 11:29 AM
Thanks, but I can explain,
The firefly crew knew that the wagon fell off but some brockend fence post along the hill edge, also one of the crew member is just look just above the wagon, the commander is looking for the enemy with his bino'c, tho show they came out of the firefly, the hach is wihtd open, another wasn't close well, and the wagon hasn't been weathered yet, I'm not too good at weathering since I've never done it before.
As for the tiger, I told you the tiger has stop for reloading, but the crew has a meeting with the commander telling the status report, to show the tank is fix, there a soldier lening on it.
Thanks for asking.
    November 2006
Posted by ww2modeler on Tuesday, July 31, 2007 1:44 PM
I think he means that the units you are thinking about placing the Tiger in with would not go well it. For example, why would they have an MG nest on a rear repair shop when they could have a rifleman satanding guard. And, they probobly wouldn't have used a Kettrankrad to transport parts for the Tiger when they could use a horse. Remember, alot of German Artillery and supplies were horse drawn. And, comoflauge or Dark Yellow on the Tiger would meen '43-45 when the German's were getting short on fuel.
edit>If the Germans left a carriage and pushed it over the side, wouldn't the tank commander be looking down the road where they preumably went because that incline looks to steep for a vehcile. And, are you going to put track marks on the road?
David
On the bench:
    February 2007
Posted by T-rex on Wednesday, August 1, 2007 11:32 AM
True, but I don't know want rifle men your talking about, the only figure with a sub MG is lisening the the commander. Remember its a small base, normally it would have been just a MG nest (well now it is since a puchhen wouldn't go well) this tiger crew where desperate for ammonition, they stop at the nearest outpost and waitend for supplie, that's why it doesn't look like a workshop. Athought I didn't know that use use horse much in the war since there not, euh strong, maybe I should swicht the kettenkrad with the wagon instead.
Hey, I'm sure that looking in the horizon on top of a hight point isn't a bad idea.
    June 2006
Posted by ps1scw on Friday, August 3, 2007 12:17 PM
Maybe the firefly could be in the ditch because it swerved to miss the trailer.
    November 2006
Posted by ww2modeler on Friday, August 3, 2007 2:48 PM
No disrepcet but, why would a tank swerve to avoid something it could just run over?
David
On the bench:
