hey guys, will wall / household plaster (the kind you use to fix holes in your walls) melt styrofoam ?
i'm building a dio, and the bulidings & armour i have is based on styrofoam. i intend to cover the foam with the plaster / putty to make roadways and terrian etc.
also what glues wont melt the foam? because i need to base the foam onto some thin plywood to give it some strength so i wont snap when moved or lifted.
thanks
If your not bleeding or broken, I don't care!
