parachutes!?!
parachutes!?!
Posted by Anonymous on Thursday, October 2, 2003 7:28 PM
Howdy! I was wondering if anyone has any idea how to make a deployed parachute for a model that is in 1/48th scale. I want to hang a JU-52 from the ceiling with the troopers droping out under deployed canapies but have no idea how to make a parachute. If you could help I would apprecate it.
Thank you very much!Cool [8D]
Posted by Anonymous on Thursday, October 2, 2003 8:40 PM
Wow, this project must be a tough one. Sorry though. I have no idea as to how to make a parachute. But maybe you can try using tracing paper.
    January 2003
Posted by shermanfreak on Thursday, October 2, 2003 8:47 PM
I'm going to take a wild stab at this .... not that I've ever tried it.
If you made the chute out of tissue paper soaked in white glue and water, and then laid it on a balloon about the size of the chute you want to make. Wait for it to dry and then pop the balloon. This might work .... I've used the tissue and white glue / water technique to make tarps before.
Maybe a cheap way to try.
Posted by Anonymous on Thursday, October 2, 2003 9:49 PM
Try a light cloth but use hobby starch (sorry can't remember a name brand but it is used to stiffen doilies and can be found in most craft stores). The stuff works awesome and dries pretty quick. I would try using rayon for the cloth, that way you can get the parachute look. Hope this idea works for you!
Posted by Anonymous on Thursday, October 2, 2003 10:41 PM
also remember that the shute is going to have areas of tension caused by the strings attached to the jumper..... if you make a mold out of modeling clay you can then use the toilet paper/glue technique and get as many shutes as you want
    July 2003
Posted by gar26 on Friday, October 3, 2003 3:16 PM
I agree with Robert using tissue paper and white glue and water. I have used this technique for making sails and flags so it should work for a parachute. But remember that you don't want it to thick. What I would try is to lay one layer of tissue paper on the ballon and then lay place some thin string for the shroud lines. Place second layer on top and possibly a third then let dry, remember to make your shroud lines long enough. This may take a little practice the tissue will be fragile but should work
gpebernat
Posted by Anonymous on Friday, October 3, 2003 5:28 PM
Thanks for the great ideas. I'll have to try them. I hope that it works. If you get anymore please let me know. Thanks a million.
