BEND PROPELLERS
BEND PROPELLERS
Posted by Anonymous on Saturday, October 4, 2003 11:19 AM
I try a crash landed plane. Should i bend all three/four blades or just the two facing the ground? Is there a particular pattern?
Posted by berny13 on Saturday, October 4, 2003 12:14 PM
Yes there is. An engine running at full power, the props will be bent forward. At low power the props will be bent back. All three/four will be bent as the engine is still rotating. With the engine at off, only the props that come in contact with the ground will be bent.
Berny
 Phormer Phantom Phixer
On the bench
Posted by gregers on Saturday, October 4, 2003 3:48 PM
you will have to check that the aircraft that you are modeling didn't have wooden blades too as they just shatter when they hit the ground. Greg
Why torture yourself when life will do it for you?
Posted by Anonymous on Sunday, October 5, 2003 4:49 AM
HE HE you got me in that AGAIN....
Posted by Anonymous on Monday, October 6, 2003 5:55 PM
poo
