not dirty enough
not dirty enough
Posted by Anonymous on Monday, October 6, 2003 8:21 PM
I am in the progress of building a scene in which a jeep is stuck in the mud and had hoped to immitate mud splattered and caked on the back and underside of the jeep. However, I have never tried or even thought about doing something like this before and wanted to know if anyone had any tips. As of now, the model has no mud on it and I have only started construction of the base, but I have tried to use toothbrushes and splattering thinned putty on a model (scrap of course) to achieve the desired effect. This attempt was unsuccesful. Tips and techniques are appriciated. Thanks
    July 2003
Posted by lizardqing on Monday, October 6, 2003 8:46 PM
I recently did a similar scene. I took putty and mixed in the color paint I wanted the mud to a pretty thick consistancy. I used an old stiffened paint brush and sort of spackeledand smeared the mixture where I wanted mud. Try this link and see how it turned out for me.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=7331
Good luck.
    July 2003
Posted by Dwight Ta-ala on Monday, October 6, 2003 11:37 PM
For larger particles, I use a stiff brush or even a toothbrush.
For fine particles, I use my airbrush.
Try to practice using different mixture consistencies and thickness to achieve you desired effects.
Posted by renarts on Monday, October 6, 2003 11:44 PM
You can use a thicker paste of putty for mud that has built up onto wheel wells and tires. I have also used celuclay that is mixed and kneaded till its smooth. Add some white glue and this will give you nice mud effects. As for the splattering you can take your mud colored paint and use the tooth brush or stiff bristled brush and "flick" your mud colored paint for splatters. Once this has dried you can use a thinned paste of plaster, colored to match your mud. This will build up and give you that desired "bogged on" mud look. Take it slow and let it build up for the best effect. But don't doddle. Plaster sets up pretty quick once it gets started so be aware of this. Clean up your tools and work area (and don't wash them off in the sink, take them outside to clean them up otherwise you'll be paying a pretty hefty plumbing bill).
The celuclay works nice, because like any mud, there is always some sort of ground detrius mixed up with it. Grass, roots, etc. The paper fibres in celuclay replicate this very nice.
Depending on the "weather conditions" you can also use a lighter shade of mud in the thinner areas. This replicates mud that has dried. The closer to the ground or the closer to the built up areas the wetter it will be, so add some gloss to it.
Don't forget to muddy up the lower parts of the pants, knees, boots etc. of any figure you may add to the scene.
Posted by Anonymous on Thursday, October 9, 2003 9:10 PM
Thanks guys.
    July 2003
Posted by gar26 on Saturday, October 11, 2003 1:26 PM
I use baby powder mixed with paint to the color of your mud and then I use a putty spatula and flick it at the vehicle
gpebernat
Posted by Anonymous on Saturday, October 11, 2003 10:23 PM
wow really? does that stay on the vehicle well?
