Scales
    December 2006
Scales
Posted by wolfie on Thursday, October 4, 2007 5:03 PM
Still kind of new to all this, I mainly work in 1/72 because i like to see a lot going on, anyway have just found a store that sells buildings, accesories, etc at a pretty good price which helps with larger dio's anyway they list 20mm and 25mm anyone know which is the better for 1/72?
    July 2004
Posted by stikpusher on Thursday, October 4, 2007 6:30 PM
I think 25mm is closer to 1/72 while 20mm should be around 1/87 scale.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February 2007
Posted by Geomodeller on Thursday, October 25, 2007 3:19 AM
Wolfie,
The 1:72 scale came about by the use of the ratio 1" = 6 feet, or in other words, 1" = 72".
Considering that 1" is approximately the same as 25mm (actually 25.4mm), then stikpusher is correct in stating that 25mm scale is the best alternative for you.
By the same rationale/calculation, 20mm is equivalent to 0.79". If 0.70" = 72", then the scale is actually about 1:90, or a touch smaller than HO (1:87 scale).
Incidentally, you can also happily use OO scale railway buildings, vehilces, animals & accessories with your 1:72 scale dioramas. The OO scale is 1:76, so the differences are barely noticeable.
