I'm making a diorama for the F-16 that I'm working on now, showing the Viper sitting on a concrete taxiway, and I have a series of stupid questions.
First, how big do I make the concrete squares? Is there a regulation size they are, does it vary, or what?
Another question: To portray the concrete, I'm using some 320 grit sandpaper (painted to look like concrete) glued to a piece of foam board (I read about this technique somewhere, I can't remember exactly, but it seems cheap and easy so I figure what the heck). To simulate the grid pattern, should I cut the sandpaper into squares and glue each individual square, or should I just draw on the grid.
And yet another question: What would be the best way to simulate, well, basically "leaky airplane" stains?
Thanks for all your help!
James "TomcatFanatic123" Eberling
Have you ever had the odds stacked up so high
You need a strength most don't possess
Or has it ever came down to do or die, you've got to rise above the rest
