camo netting
    December 2003
camo netting
Posted by dostacos on Sunday, December 30, 2007 7:28 PM
I know that eduards has a photo etch net but that is $$$ what do all ya'all use?
I have been thinking about using stuff from the first aid kit...
Dan support your 2nd amendment rights to keep and arm bears!
    July 2003
Posted by madmike on Sunday, December 30, 2007 7:48 PM
Gauze bandages work very well indeed. I use a bandage with a very fine mesh (1:72) as required.
I cut to shape and carefully place the cut piece into a mix of water, acrylic colour and white glue. the drape or roll as needed. The glue will lock the threads together and set the netting to any needed shape.
Then it is easy to cut thin strips of Tamiya tape and add to the netting once dry.
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
Posted by Kelly_Zak on Monday, December 31, 2007 9:12 AM
I do the same thing as Mike does, but I also use poultry stuffing bags, bought at the local grocery store. It's prettly much cheesecloth, and for 2 bucks you get alot of netting! I still have alot left over from a package I purchased over 2 years ago.
"There you go with those negative waves again!"
    December 2003
Posted by dostacos on Monday, December 31, 2007 3:05 PM
sounds good, I have lots of 4x4s in the first aid kit so I will try that first, I will do a small dio with a british 25 pounder for practice then I have a fantasy of doing a German 88 in a pit like they were in the band of brothers.
