Substructure/base
    June 2007
Substructure/base
Posted by PastaDNA on Saturday, January 5, 2008 5:07 PM
Hi fellas,
I'm a 'born again' modeler and I like dioramas. It's been years since I have modeled and I'd like to know what everyone uses for a platform. Plywood? Styrofoam? How thick? I'm starting to do some scenery and I'm using celluclay. Any suggestions are appreciated - thanks.
Posted by waterboy on Sunday, January 6, 2008 5:48 AM
Hi PastaDNA, Welcome back to this insane hobby! What I usually use for my dio bases is a piece of unfinished wood that they sell at my local craft store( hobby Lobby, Michaels, ETC.).
If you are using celluclay for you groundwork you must seal the wood with a varnish first or the water in the celluclay will warp the wood. Also if you mix some white glue into your celluclay mix it will adhere beter to your base.  Good luck
"The reason the American Army does so well in wartime, is that war is chaos, and the American Army practices it on a daily basis." - from a post-war debriefing of a German General "There's a fine line between a hobby and a mental illness."
    June 2007
Posted by PastaDNA on Sunday, January 6, 2008 8:46 AM
Must it be varnish? Or, will any 'sealer' work? Thanks for the advice.
Posted by ajlafleche on Sunday, January 6, 2008 8:49 AM
There's a discussion about this here
