dostacos wrote: |
Tamiya has a machine gun crew using a watercooled machinegun but after the very beginning of the war was it used much? |
Two things happened, really. The Army adopted the M1919 to replace the water-cooled M1917; then the tactics of maneuver warfare made emplaced machine guns a distinct rarity. Which did not stop the issue of water-cooled MGs, the Tables of Organization for many US military forces kept changing faster than the supply system could react.
Also, does anyone make 30 cal. air cooled machine gun figures in 1/35? |
Couple. Collector's Brass makes some very spiffy lost-wax cast MG's and parts.
still you seem to be a nice TARGET |
Well now, I've always suspected that the Tamiya "pose" was taken from a pre-war photo of soldiers training up on a range at Ft Riley. It's also good to remember that you are supposed to, by doctrine, place your MGs so that they create "beaten areas." You are not supposed to be in "direct fire," as that means the enemy is too close. The idea is that you set up the tripod, brace it with sandbags, then get out the firing table, and plot some places where you want rounds to fall on the bad guys so that they pick another, harder path to engage you (or mend their evil ways and go home). Would not be uncommon to set up "fires" with your MG that are 900-1200m out. MG gunner is not much of a target for a rifleman 1/2-1mile away as is, with MG rounds falling about him, even less so.
not as bad as the German one where the guy hangs onto the bipod while the gunner stands, kneels or whatever BEHIND the other guy. I mean what did he do to get THAT job, |
Well, the German infantry organized differently than everybody else in WWII. Instead of having 8-13 guys carrying rifles with a couple of MGs supporting them, the Germans did the reverse. Their infantry companies were (doctrinally at least) all set up as MG squads with riflemen in support (and humping ammo cans). Which means, in the assault, you can have situations where you need a base of fire Now, not later. So, the A-gunner (assistant MG gunner is soooo long to type<g>) gets the joy of not only carrying an ammo can, the spare barrels, and his rifle, but also gets to be the "snap" emplacement, too . . .
T.J. Mullins has written that he did a similar thing while an M-60 gunner in Viet Nam, in that case because of being in tall grass (drop prone and have no visible target to aim towards, oops).
Always thought the Tamiya kit would be fun to set up as a dio of a machine gun range. That, if only for being able to juxtapose a number of figures uniquely. Only real problem would be the great huge monud of expended brass to do it right . . .
