Wash???
Wash???
Posted by Anonymous on Monday, October 27, 2003 4:53 PM
I'm not quite sure where to put this question... so here goes. How do I do a wash on a model???
Posted by djmodels1999 on Monday, October 27, 2003 5:43 PM
Quite simple really! First of all, my technique involves different type of paints at different stages so that I'm not risking big disasters... Say for instance you painted your model with an enamel base. If you do a wash straight away with an oil-based wash, you're gonna let the thinner in the wash do its 'magic' with the paint below. Believe me you do not want that!
So instead, use a water-based paint. I use artist's watercolors that comes in tubes for my washes. You can use them over acrylics and enamels or even cellulose paints and will not damage them.
Mix a little bit of the paint with water, a drop or two of washing-up liquid and a few drops of white vinegar. This very thinned down paint is a wash. You can either slap it all over (as I do!) with a wide flat brush, or be 'delicate' and apply it selectively, in recesses, with a very fine brush... If you feel the effect you want is not there yet, slap on another coat after the first has dried. If you feel your first coat is too much, place the model under the tap and let it clean itself. Then start again. After that, in my text book, comes drybrushing (that will highlight the raised areas, i.e. do the opposite of a wash), and the weathering.
If you do not want to use artist watercolors, a wash made out of acrylic paint, water (or isopropyl alcohol!), washing up liquid and vinegar will work well too. However, if you've got too much of it on, be fast in cleaning it up under the tap. Once acrylics have dried, you're gonna have a h.. of a job removing it from all those recesses!
Oil-based washes are OK too, but either ler your enamel camouflage dry a loooooong time first, or use them over acrylic base color. Simply use a bit of paint and some thinner to get the wash you need. They are slightly less forgiving than acrylic washes.
In any case, my washes are made of a color that's much darker than the base coat. I normally use a shade of dirty black/brown called Sepia. This works really well onto Olive drab, greens, German camoflages, panzer grey and the like. Pure black is too strong a contrast!
Good luck!
Posted by Anonymous on Monday, October 27, 2003 8:27 PM
Airbrush,
Nice post djmodels1999!
For a black wash I use Tamiya XF-1 Flat Black and Tamiya X-20A Thinner. The ratio changes for the model and use on the that model. However as a rule of thumb, I go 1:8 paint:thinner.
I use this on auto's and my bikes. I like to use 1:15 or so and wash it very lightly over Tamiya XF-56 Metallic Grey to give the engine a nice warm look.
dss902
Posted by djmodels1999 on Tuesday, October 28, 2003 1:17 AM
I forgot to mention why you put washing up liquid... It help breaking the water surface tension, i.e. the propency of water to re-congregate into drops. It will help the water flow all over those recesses.
The vinegar ? When a wash has dried on your model, there are often evident marks showing where it was was applied, and where, despite the washing up liquid, more liquid and paint ended up (the bottom parts of the model normally!). The vinegar seems to help in preventing the creation of those hard demarcation lines, leaving you with a more even finish, just about ready to be drybrushed.
Of course, this only applies to water-based washes...
Posted by Anonymous on Tuesday, October 28, 2003 9:54 PM
To me i sounds better to use water colors!!???
Do you use them exclusvley????
Posted by djmodels1999 on Wednesday, October 29, 2003 1:47 AM
Ron, almost yes. I just find them so easy to use and forgiving. Occasionaly, I'll use artists oils instead, over an acrylic base. Them too are very usefull because of the time they take to dry, allowing for changes to be made well after application.
Oils are my favourite medium when it comes to weathering though.
Posted by dubix88 on Wednesday, October 29, 2003 3:35 PM
HEY,
Check the July 2003 issue of FSM. It has a great cover story on how to wash and drybrush. Also try a forum search.. There is been tons of info out there to help ya.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
