Finished Revell 1/48 B-29 Superfortress "Humpin Honey"
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 1:48 AM
Well guys, here she is.  My newly finnished B-29, the "Humpin Honey".  It is a beast of a model that took me over 3 weeks to complete.  I had built this kit when I was a kid, needless to say, it turned out better this time.  This is the fourth serious plane I've ever built, so I know its not perfect, but what model build is.  Let me know what you guys think.
I started her by painting the interior with Testors dark flat green with dry-brushing to add a warn effect.  Some of you may have seen these pictures during the build.
I painted the bombs Testors Olive drab.  I brushed them by hand with a fine soft brush.  They turned out nice.  The bomb bay was painted aluminium as per the directions.  I like the contrast it provides.
After the two fuselage halves were done, I stitched her together and laid on a nice coat of Tamiya putty.  Not my favorite part of modelling, it's such a pain in the butt.  I am inexperienced when it comes to planes, so getting the joints to look right was a challenge.  I chose not to fill the gaps in the engines because I knew it wouldn't turn out right and I felt it would look better if I left them...just played it safe.
I did however fill in the gapps in the wing halves between the engines and in the fuselage, which was a no-brainer, it had to be done to achieve a decent finnish.
The landing gear bays were painted Testors dark flat green and also dry-brushed.  I had never used this technique before and I love it, it looks so cool if done right.
Even though this bird did not have an antenna tied from the tail to the fuselage, I felt it would add a nice touch to the finnished product...I was right, I love the way it turned out.
I drilled a microscopic hole in the antenna glued to the fuselage, than another in the tip the tail, there is a small 'nub' that drilled out just fine.  I used the small drill bit set i used while drilling out distributor caps and cylender heads when I used to detail my engines on cars.  I than used black thread to depict the antenna...I love how it turned out.  I know its not accureate to this specific plane, but its a personal touch.
The front landing gear doors were half painted yellow, which classifies this plane as a heavy bomber.  The front wheels were supposed to have a cover on each wheel with a black and yellow turbine style decal.  I couldn't make the covers look right...What I really needed was a set of leather punches, to make the covers perfectly round...I couldn't do it by hand.  I kept messing it up, so I gave up and painted the wheels instead.
The whole plane was painted with Tremclad Aluminium.  It was a mistake that I wish i could take back.  The hobby store I use didn't have any Tamiya paint.  I was too impatient to order it and it is expensive.  Instead of paying 20 bucks for two cans of the good stuff, I cheaped out and got a 3 dollar can of Tremclad...oh well, lesson learned.
The paint isn't bad, it just lacks that nice glossy sheen that would have came if I used the Tamiya paint...that stuff is money.
Here's wher my inexperience shows, I painted the wings and fuselage separately.  If I could have done it over, I would have done it all in one piece...like Feldmarschall's B-29.  I thought it would make things easier in the long run, which it did, but it would have looked better if I filled the gaps and painted the whole thing in one shot...lesson learned.
After the fuselage was dry, I taped off the tail rudder and sprayed it with Testors yellow. Once it was dry, I went in with a brush and hand painted the separation lines in the corners, and the control surfaces to mach the fuselage...it gives it a clean look I think.
The windshield pieces (which were a terrible fit) were hand painted using a fine brush and some testors.  After seeing these pics closer, it looks like I got a wee bit of touch up left to do!
Here's a few pics of the underbelly of the beast.
Those little decals were a pain, but worth the effort.
I did a little research on this plane.  The "Humpin Honey" was delivered to the 452nd BG on January 11th 1944 to Walker Army Arifield in Kansas.  It departed the U.S on April 10th for assignment with the twentieth Air Force arriving in India six days latter.  It took part in a raid on the Manchuria Airoplane Manufacturing Company and an adjacent arsenal at Mukden.  80   B-29's hit the primary target and ten others hit a near by marshalling yard.  Superfortress gunners claimed 10 downed Japanese fighter aircraft, 10 probably destroyed and 30 damaged.  Seven B-29's were lost, including the "Humpin Honey".
Sgt. Walt Huss, the "Humpin Honey's" right gunner claims the plane was downed over Mukden after being rammed by a "Tojo" fighter.  Left gunner Sgt. Ken Beckwith and himself were the only survivors.  Both survivors were captured and spent the rest of the war in a Japanese P.O.W camp in Mukden.
In taking on this build, I wanted to pay my respects not only to this beautiful aircraft, but to the men that flew her into battle and gave the ultimate sacrifice.
I hope you all enjoyed the build and the story of this truly great aircraft.  Thanks guys!  If any of you are atempting this beast and need any help or tips, please do not hesitate to ask.
Thanks to everyone who helped me along the way, you know who you are.
On the go...Trumpeter 1/72 Tupolev Bear Soviet Heavy bomber...Tamiya 1/48 RAF DeHavilland Mosquiot Mk.II
    January 2006
Posted by Wirraway on Monday, October 20, 2008 2:43 AM
Hey Tiny.....take a few pictures next time will 'ya.........Big Smile [:D]   Just razzin' ya.   Seriously tho', you might want to give the guys with dial up.... a little heads up....48 pictures takes a while to load ya know.   I like the build, I think these big mutha's are a "must built" for any airplane modeller.  Certainly looks better than when I tried to do "Bockscar" from an old kit I got off e-bay.
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    August 2007
Posted by Habu12 on Monday, October 20, 2008 2:56 AM
Only 3 weeks? Good haul!
Hey Wirraway, your avatar makes me want to....step on a crack..break your momma's back...give the past the slip...Big Smile [:D]
On the Bench: 1/48 F-16N: FINISHED! 1/48 F-16DG Aviano: FINISHED!! Stealing joy since 1993.....
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 2:58 AM
Sorry for all the pics man...I didn't think aboot that.  I trimmed a few out.
    January 2006
Posted by Wirraway on Monday, October 20, 2008 4:46 AM
Yeah,  I bet Gen Y and Gen X dont know what a power dome is.....................Smile,Wink, & Grin [swg]
    November 2003
Posted by tempestjohnny on Monday, October 20, 2008 6:36 AM
Tiny fora semi-tough build that came out really nice.  You know the areas that you had trouble with and dealt with them in a way you felt you could GREAT JOB.
    July 2004
Posted by mucker on Monday, October 20, 2008 6:41 AM
Very nice, Tiny. Good call on the decals!
    August 2006
Posted by wyoroy on Monday, October 20, 2008 7:59 AM
Tiny, looks great, well doneThumbs Up [tup]
Roy (Capt. Wyoroy FAAGB/USNFAWGB)
John 3:16
Posted by Anonymous on Monday, October 20, 2008 8:15 AM
Wow...anyone willing to tackle those old Monogram 4-engined beasts are aces in my book...great job on her, especially with an OOB build...three weeks is mighty fast for a plane of that size! Two thumbs up...
    October 2007
Posted by Summit on Monday, October 20, 2008 8:20 AM
Tiny, - Fantastic Buildup. You have awed me with this Beast . Thumbs Up [tup]Thumbs Up [tup] Now where are you going to Display this Real Estate Hog ? Cant wait to see what your next build will be.
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    September 2003
Posted by Daywalker on Monday, October 20, 2008 8:36 AM
Sign - Ditto [#ditto] Three weeks?  It woulda taken me longer than that to paint the cockpit.  Also wouldn't have turned out as nice as yours.  Give yourself a big ol' pat on the back for this one. Approve [^]
Frank
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 8:59 AM
Thanks alot guys, I plan on hanging her from the ceiling in my apartment with some fishing line...better use some heavy test line though!  My next project is a 1/48 Monogram B-17 Flying Fortress.  I wouldn't mind getting an airbrush for this one.  I've been dying to crack out an awsome cammo job on one of these planes so I need the airbrush and a little practice.  I also have a Atileri F-22 Raptor to do and I'd like to learn how to do weathering like I've seen in some of the other threads.  Those planes look so real, I'd love to try that.
Anyways, thanks againg guys...stay tuned!
    February 2008
Posted by bspeed on Monday, October 20, 2008 9:06 AM
Congrats on a nice BIG build :) really enjoyed the pics!
    November 2007
Posted by darth_trader on Monday, October 20, 2008 11:06 AM
Excellent build Tiny, display it with pride Smile [:)]
I think the paint job looks superb.
    February 2006
Posted by DantheMan85 on Monday, October 20, 2008 11:43 AM
Nice job Tiny!!!!!!  She's very beautiful, that aluminum finish just shines like a winner.  Your's looks a heck of alot better than mine.  Thumbs Up [tup]
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    April 2008
Posted by Von Alfalfa on Monday, October 20, 2008 11:59 AM
WOW! great paint finish... I also have one b-29 in my stack, haven't started to build yet since still dunno where I going to put it when finished! Hope to do a great paint job as yours when I start mine.
    September 2006
Posted by the Baron on Monday, October 20, 2008 12:05 PM
Yes, nice job, Tiny, brings back memories of building this kit when I was in high school.  You did a nice job, I think the finish looks pretty good.  If you're worried about the shine or glossiness of the finish, you could always try using a spray of Future (Johnson's Kleer, outside the US) over the paint (though you would need an airbrush-try it on a future project-no pun intended).
It's a great kit, and a job well done (and more pictures are always welcome, too Wink [;)]  )
Regards,
Brad
Posted by Butz on Monday, October 20, 2008 12:31 PM
Hey Tiny,
 Great build my friend!! I like how you dealt with the obsticles that you incountered and took notes for future builds..
 For an older Monogram kit, you sure did her justice as well as for the crew!! They would be proud of her!!
 Thank you for sharing
Flaps up,
Rangers Lead The Way
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
    February 2007
Posted by DesertRat on Monday, October 20, 2008 1:05 PM
She's an awesome build, Tiny! Well done! I built that one in my early teens, and it was a bear to complete. Basically mine turned out pretty horrible (but I learned that it's not possible to get a good NMF drybrushingBlush [:I]) But when I next go to tackle that one again, if it turns out half as well as yours, then I'll be satisfied!
Only one question.... How are you going to display that behemoth?Cool [8D]
Warmest regards,
Roger
    October 2004
Posted by sfcmac on Monday, October 20, 2008 1:50 PM
Thumbs Up [tup]Thumbs Up [tup] Looked at this last night before bed.  Were in the world are you gonna keep it?
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 1:52 PM
Hey guys, I've gotten a couple questions about how I'm gonna display the B-29.  I thought she'd look good flyin'.
Looks cool with the 'Tiny' squadron in the back ground eh?
Just wanted to say thanks for all of your kind words, I apreciate it.
    August 2008
Posted by Higgy on Monday, October 20, 2008 2:55 PM
Wow that turned out great Tiny! I'm still working on the cockpit of mine LOL. (although the B-29 has taken a back seat over the past week to my Leopard A62 build)
Born to land hard.
    December 2007
Posted by dlowman on Monday, October 20, 2008 3:23 PM
Thumbs Up [tup] Tiny, that is an excellent build. Your patience and attention to detail shows through. Thanks for sharing, and I agree about the antenna wire, a nice touch.
Cheers, Make a Toast [#toast]
working on Tamiya 1/48 A-10A Thunderbolt II and trying something different a Tamiya 1/35 Chieftain Mk. 5 Tank
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 3:34 PM
Thanks Dave!
    January 2007
Posted by trexx on Monday, October 20, 2008 4:37 PM
Crisp build... and quick too.
Great ceiling decoration!
All those wheels hanging out are such a drag though! Wink [;)]
Posted by Swanny on Monday, October 20, 2008 4:42 PM
Excellent build, Now you need to build an addition to your garage to display it in.
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 5:00 PM
Yah, no kidding lol. It's gonna get out of hand when I get my B-17G and a B-52 Finnished.
    September 2012
Posted by namrednef on Monday, October 20, 2008 6:09 PM
Great build Tiny! (I must admit I was getting yours and The Feldmarschall's build confused!
Great work!) Thanks for the history lesson also!
If I had one criticism....maybe you might put some Future on fingertips and run it down the antenna thread to seal the fine 'hairs'. A wonderful build!Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]
    October 2008
Posted by -Tiny- on Monday, October 20, 2008 6:20 PM
What is Future? not familiar with it...
    August 2008
Posted by Higgy on Monday, October 20, 2008 6:23 PM
Future floor polish. Should be able to get it any grocery store, Rona, Home Hardware, Home Depot etc.
Born to land hard.
