Wingnut Wings Sopwith Pup WIP
    October 2008
Posted by P mitch on Sunday, March 10, 2013 2:27 PM
In the WW1 group build I said I'd do a WIP so here it is. Any mistakes will be shown as I'm fine with people seeing my mistakes and I hope some one can learn from then, just as I do. I consider myself an average modeler (on a good day).
So here goes. The kit is below and in the box looks great
So the build starts as always with the cockpit. I've read in a few places that the cockpit floor can cause a problem as its a little thick. Rather than trying to sort that problem later I decided to sand it thinner now as it would be easier and I could keep an eye on how thin I was making it.
After that I attached the supports for the feet control. Then I decided to start the impossible task of making some turn buckles. These things are so small!!! I have cheated a bit by buying the parts from a company called "Bob's Buckles". I have some smooth grip pliers which I used to hold the eye parts as I put on the tube. I tried to put them together all at once but soon realized that that wouldn't work. I ended up putting one side in and letting that set, I'll do the other side later when I feel up to it.
At this point I decided to work on the engine. its an easy build which i decided to complicate by removing the spark plugs with some from "TaurusModels" again these are tiny but I found that rather than (after loosing one to the carpet monster) that using the side of a set of tweezers rather than the tip held the part and allowed me to place it well on the engine. I wanted to add as much detail and I could so decided to add the electrical wires for the spark plugs, to do this I used EZ-line in rust colour (it was the first one I picked up but think it will look good)
So thats where I'm up to so far. Please let me kow what you think any ideas or suggestions please say so if I can I'll add it to the build
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    October 2010
Posted by Bob H. on Sunday, March 10, 2013 4:12 PM
It looks like you're on the right path so far. I'll try to keep tabs on this build as I am looking to learn as much as I can. Thanks for taking the time to post your project.                               Bob
    September 2003
Posted by checkmateking02 on Sunday, March 10, 2013 4:52 PM
That is one ambitious project.  Looks good.
    February 2013
Posted by VTmodeldude28 on Sunday, March 10, 2013 7:04 PM
Looking good, I'm very curious to see how one of these builds up! How much did it cost you? Those kits seem expensive...
On the bench:
1. Eduard 1/48 Mig-21 MF
2. Tamiya 1/35 M41 Walker Bulldog
3. Tamiya 1/35 T-72 M1
    February 2006
Posted by ruddratt on Monday, March 11, 2013 12:32 AM
Phil, you're off to a fine start. The only thing I may have done a little different is used a finer monofilament thread or stretched sprue for the ignition wires and ran them straight from A to B with no curve. Taurus models really makes some neat stuff, don't they! - those spark plugs are cool! Yes
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    October 2008
Posted by P mitch on Monday, March 11, 2013 3:59 AM
VTmodeldude28  - cost me with shipping £60 so will be about $80 or so
ruddratt - I agree on the thread and need a lot thinner for the rigging but I'm having trouble finding it thin enough. Can't figure out what weight I need so if anyone can help with that it would be great
Phil
    October 2008
Posted by P mitch on Monday, March 11, 2013 5:54 AM
Ok quick loot today and monofilament (or fishing line to us mortals) will go down to 0.06mm, I've got some of that and 0.25mm on the way. As an experiment when it arrives I'll use both so everyone can see the difference
Phil
    October 2008
Posted by P mitch on Wednesday, March 13, 2013 4:00 PM
Update to the experiment for the turn buckles. The 0.25mm (10lb line) is way too big, it will go through but there is no way it will double back and go through again. The 0.06mm (1.4lb line) will go through twice no problem but looks too thin to me. So it looks like I'll need 0.1mm to look right and work, lucky i have a friend who fishes really! Below is a picture to show what I'm talking about, as always any suggestions happily recieved
Phil
    October 2008
Posted by P mitch on Sunday, March 17, 2013 12:07 PM
This weeks update below
First I've decided on the line for the rigging. After my experiments I decided on 0.1mm, thin enough to be workable think enough to be able to see it. Pitty the EZ-Line is just way too think, Picture below shows top 0.25 middle 0.1 and bottom 0.06
Next I did some more work on the engine and after the suggestions took of the line I had used for the plug leeds and used 0.25mm which looks much better. The engine was painted Allclad Stainless Steel then a wash of Tamiya Black was used to pick up detail.
The exhaust was painted Copper using Oro Liquido - not a company i have heard of before but I like the look
I have done some work on the cockpit wood painting up the inside frame
I also decided to be clever and try preshading for the wing spars. As I said at the start I would be honest about mistakes and I made some here, got a bit too excited and put way to much paint on for preshade, I need to decide whether to just paint over with primer or see how the top colour works. I could always just use some sanding and take it back that way.
As always suggestions or ideas welcome
Phil
    February 2006
Posted by ruddratt on Monday, March 18, 2013 2:27 AM
Phil, nice work so far man!  Are you going to do the wing ribs as well?
    October 2008
Posted by P mitch on Monday, March 18, 2013 4:08 AM
Yes the plan is to do as much as possible, push myself and give info to people who may be a bit scared of going outside their comfort zones
Phil
    October 2010
Posted by Bob H. on Monday, March 18, 2013 10:35 PM
Lookin' good so far. I'll keep on checking in on your progress. Thanks again for posting it.       Bob
Moderator
    September 2011
Posted by Tim Kidwell on Tuesday, March 19, 2013 9:36 AM
Nice stuff, Phil. It will be awesome to see how all this work pays off in the end.
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
    February 2006
Posted by ruddratt on Tuesday, March 19, 2013 9:27 PM
 Phil - great idea to shade the ribs, but have you considered post-shading them? I've seen it done and tried it myself, and the results blew me away. For the upper surfaces, start with a light-to-medium coat of your PC-10 color just on the ribs, then mask the ribs with tape the appropriate width. Next, apply your final coat of PC-10 to the entire wing, remove the masks, apply a very light coat of your PC-10 for blending and post-shade over the ribs front to back with Tamiya smoke. It highlights the ribs beautifully. For the underside, apply your CDL color, mask the ribs, and lightly post-shade with a thinned medium brown/earth color, remove the masks, apply a second very light coat of your CDL just on the ribs and just enough to blend them, and you're good to go.
    October 2008
Posted by P mitch on Wednesday, March 20, 2013 3:28 AM
Like the idea and I'll give it a go on this build. I'm looking to paint the wings as usual for a WW1 aircraft before I attach them to the build so it will be a lot easier to paint.
Last night I was building turn buckles so didn't get a lot done other than that, my eyes just wouldn't take it, but I'll take some pictures and post when I can
Phil
    October 2008
Posted by P mitch on Sunday, March 24, 2013 3:17 PM
This weekends update
Doesn't look like much today but its about 3 hours!!
Things I learn are the slower you go the better and breath deep often. I manages one side without problems, on the second side I was tightening the lines using a very little heat and they all just snapped. lesson there to all is as always you can always do more you cant do less. The way I did it successfully was to light a match then put it out and use the burnt match heat to give the heat. I'm not sure may sanity will take doing many more so I'm going back to the normal construction for a while.
Should do more next week as we have a four day weekend, I think its time to get some paint on some parts too. As always any ideas let me know
Phil
    April 2013
Posted by Bob Von Buckles on Sunday, April 7, 2013 3:50 AM
Hi Phil,
 Great work thus far Wink
You may want to take a look at fishing line made by MAXIMA. Their 2lb (0.12mm) line is just the ticket for 1/32 birds. It's the line I use 90% of the time. It passes through the 0.5 tube and eyelet with wiggle room (tube run through with a 0.3 HSS drill bit to clean out swarf)  to spare. Image below.
Good luck!
Von Buckle Yes
    February 2006
Posted by ruddratt on Sunday, April 7, 2013 8:23 PM
Looking good Phil. I can relate to the time involved in fabricating and wiring in those buckles. A lot of it can pass quickly - probably why I opted for the Gaspatch buckles this time 'round - actual bench time is hard for me to come by these days. Wink
Bob, I've been tempted to try that 2lb test, especially for the added structural strength it gives to the airframe (IOW, does what rigging is supposed to do). A few ?'s though, like how well CA bonds to it, and also if there is a tendency for lines to sag over time, and if so, how to re-tighten them.
Posted by jeaton01 on Monday, April 8, 2013 1:07 AM
The rigging looks pretty good, Phil.  Apparently I have that to do next on my DH-9a.  Anybody ever try Spider Wire fishing line?
John
Moderator
    September 2011
Posted by Tim Kidwell on Thursday, April 18, 2013 11:57 AM
Hi Phil,
So how goes the Pup?
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
    October 2008
Posted by P mitch on Friday, April 19, 2013 5:04 AM
In the past 15 minutes I've managed to get the cockpit side up after running the rigging for all the controls. For a change I used Ez-Line, its a little thinker and is a nice black so should stand out against the back ground. I'll get some pictures together this week end when i should be able to get the seat and instrument panel installed
Phil
    October 2008
Posted by P mitch on Friday, April 19, 2013 12:16 PM
Picture updates
Moderator
    September 2011
Posted by Tim Kidwell on Friday, April 19, 2013 1:12 PM
Nice work, Phil. Having rigged my cockpit recently, I'm happy to be through that particular gauntlet. Is that lozenge I see up under the pedals?
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
Posted by Gamera on Friday, April 19, 2013 1:39 PM
Phil: Just fantastic Phil, you guys are going to convince me to run out and pick up one of the Wingnut models myself...
    March 2013
Posted by Tatooine_Todd on Friday, April 19, 2013 2:29 PM
Great work! I'm watching this thread with interest as I just ordered a SE.5a 'Hisso'
from Wingnut Wings.
    October 2008
Posted by P mitch on Wednesday, May 1, 2013 4:06 PM
Ok new update with pictures below.
Had a good think about the cockpit control cables and decided that I needed something to glue them too so added a bit of bracing.
I've fixed one side and will be sorting the control cables this weekend. I have noticed one problem with the Wingnut instructions, the cockpit cover isn't mentioned at all! It just appears (bit of a Dragon flash back there). I was a little worried that it was going to be a problem but the part is there so will add it at some point.
I have done some work on a base for the kit. Used the old fashioned picture frame which I built up with some heavy artist card and a good coat of Tamiya Field Gray
I then added a mat from Reality In Scale which looks very nice. Small problem in that it was about 5mm short on both sides. I've filled the gap but I think it still needs some work to blend it in
I should get the cockpit closed up this weekend and start work on the green paint and some other bits to get a good run at it on a long weekend
Phil
    February 2010
Posted by EBergerud on Wednesday, May 1, 2013 5:04 PM
Phil
Looks like a marvelous build coming along. For recreation sometimes I look at the gallery at Des Delatorre's terrific site www.ww1aircraftmodels.com or at Bob's Buckles.  Yours looks like it's going to be in that category. Must be something about biplanes or ships that brings out the creative juices because even though I like all modelling, a good bipe or ship is something special. Maybe it's the fishing line. (In case you want to check another very nice Pup build, Doogatx here did a WNW Pup for the Great War GB on this board and is on his site doogsmodels.com/.../sopwith-pup-rnas ).
The ship modelling guru Jim Baumann came up with a terrific idea for fighting rigging sag: works for monofilament, stretched sprue and coated fly tying line. He burns an incense stick and watches the smoke go up: it's warm enough maybe an inch and a half away - just keep it moving. Only way I know to be able to see where the heat is going and quit as soon as you see things tightening up. It works really well on planes and 1/700 ships because you can handle the model as well as the incense and come up from any angle. (I screwed up some rigging once doing that because of a California earthquake tremor - caused me to touch the line with the lit incense: burning incense will cut 1lb tippet. Minus such things it works great.
If you use metal tubing, how long do you make it for 1/32 scale? I'm going to make a run to Bob's Buckles to replace some that I misplaced and am not really sure about the length.  Advice?
Be watching. I've got a Pflaz III at home and am waiting inspiration.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
Moderator
    September 2011
Posted by Tim Kidwell on Wednesday, May 1, 2013 5:34 PM
The Pup is progressing nicely, Phil.
I've started giving some thought to my D.VII's base. Gotta get out to Michael's or Hobby Lobby and look for some materials.
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
    October 2011
Posted by Chuck Davis on Wednesday, May 1, 2013 6:07 PM
Phil - beautiful work so far, sir!
Tim - as an option for bases, you could check this place out: http://www.modellers-warehouse.com.au/Wild%20places/Foliage%20mats%201%20page/scalemodelinggra.html
Chuck Davis
Moderator
    September 2011
Posted by Tim Kidwell on Wednesday, May 1, 2013 6:13 PM
Chuck Davis
I don't want to tip my hand, but I'm not going with a realistic base. I'm shooting going for one that commemorates the GB.
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
