**Finished** P-47D-16-RE "Pied Piper", Lt. Cipipen, 310th FS
GAF
    June 2012
Posted by GAF on Friday, May 24, 2013 9:34 PM
She's finally ready after the canopy debacle.  But it cleaned up nicely, so all's well that ends well. Smile
This is the P-47D-16-RE of Lt. Cipipen, 58th FG, 310th FS. The 310th "was converted into an operational squadron in March 1943 at Bradley Field, Connecticut, being re-equipped with P-47 Thunderbolts. Was deployed to the Southwest Pacific Theater, being assigned to Fifth Air Force in Australia in November 1943. Began combat operations in February 1944, providing protection for U.S. bases and escorting transports initially, then escorting bombers over New Guinea and sea convoys to Admiralty Islands. From Noemfoor, bombed and strafed Japanese airfields and installations on Ceram, Halmahera, and the Kai Islands.
Moved to the Philippines in Nov, flew fighter sweeps against enemy airfields, supported U.S. ground forces, and protected sea convoys and transport routes."
First, here's some shots of her before the complete weathering effects were applied.
The scheme is a little different from the box version of the paint job.  The cowl flaps are painted alternating red and natural metal.  Apparently, there is some evidence that the aircraft was painted this way and at least one decal company (Aeroscale) shows the aircraft in this paint scheme.
And now after weathering...
This was the first plastic aircraft model I've built in about 40 years, so it was a test bed of sorts.  I went a bit far in adding stuff to the old Revell/Monogram kit : brake lines, new instrument panel, gunsight, resin wheels, air intake, brass gun tubes.  The antenna wire is rubber band bead string, 0.5mm thick, along with the lower brake lines.  The pilot was placed in the cockpit to help hide its lack of detail, and I managed to get his arm up as if he were grabbing the canopy.  The harness is masking tape cut to size and painted tan, then glued in place.  The cowl flaps were cut apart, but that was probably not a good idea.  They were really hard to clean up afterwards, and I won't do that again.  I never could get the seam in the wheel wells filled completely.  They're a bear to deal with.
Painting was done with brush and spray cans as I don't have a place to use an airbrush.  That's why the paint job is mediocre.  The use of Silly Putty for demarcation was quite a useful technique.
Keeping up with the theme of going all out, I placed every stencil included on the decal sheet on the aircraft.  Quite a chore!
Several weathering techniques were tried out, including dry brushing silver, india ink wash, sandpapering, streaking with paint thinner and diluted white paint, and artist charcoal and pastels.  I overdid it in places.
This was really a learning experience in building for me.  I hope it helps in finishing up the next one on the table:
Thanks for looking!
Gary
    February 2012
Posted by lawdog114 on Saturday, May 25, 2013 12:44 AM
That looks fantastic Gary.  I love the PSP base too.  I still thought the moisture excuse was clever..
Joe
    May 2013
Posted by Mr Canberra on Saturday, May 25, 2013 5:28 AM
Very nice work Gary! I have a soft spot for the Thunderbolt as it was my dad's old mount, you've tuned out a fine model there, and a nice finish from a fellow brush painter. Keep up the good work! Cool
John
    February 2011
Posted by Reasoned on Saturday, May 25, 2013 9:15 AM
Hey for the first kit in 40 yrs I'd say you haven't missed a beat!  I think she looks great..... and no AB to boot, that's truly impressive.  Nice to see the old Revellogram P 47 RB, I've got that up next in my build routine, again nice job.
BTW, what's the bubble top in the last frame?
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
GAF
    June 2012
Posted by GAF on Saturday, May 25, 2013 10:10 PM
Joe, John, Reasoned:  Thanks for the nice comments.  She's not completely brush work.  The spray cans really helped, and came out better than I had hoped.  Although it doesn't hold a candle to the work you three have posted, it's okay for a first try.  I'll try to improve.
Reasoned:  Got a Revellogram RB coming up?  Be aware that the canopy is mis-matched.  It's okay if you pose it open, but it is too thick to fit well in the closed position.  You will also have to use some clamps and glue on parts, as my fuselage halves didn't fit together well.  But, it's a Revellogram and that's expected.
The Bubbletop is a pure Monogram.  I first got it back in 1969 or 1970, and it's been in a box for that 40 years or so traveling around with me.  I'm "restoring" the old girl to display status.  Big Smile  It's in the colors of Capt. A. Hunter, 35th FG, 40th FS, also a Pacific bird.
    February 2011
Posted by Reasoned on Monday, May 27, 2013 7:49 AM
Excellent GAF, looking forward to the "reconditioned" jug.  Thanks for the heads up on the RM P-47, they have their own little idiosyncrasies after all these years.  BTW, I just got back to the hobby after 35 years and my first build was a pooch (unlike yours) compared to my recent.... that's why it's fun!
Posted by Gamera on Monday, May 27, 2013 9:01 AM
Gary: She looks great, I can't even tell the canopy frosted. And it's nice to see a Pacific jug for a change of pace!
The bubbletop looks good too, I'd never be able to get results like that with a can. The red nose scallop looks perfect!
    September 2003
Posted by checkmateking02 on Monday, May 27, 2013 2:13 PM
It's a great-looking Thunderbolt.  Nice work.
