Burnishing Bare Metal Foil?
    August 2003
Posted by Bwog on Thursday, November 13, 2003 11:10 PM
What is the best method of Burnishing Bare metal foil for the brightest (most reflective) results?
thanks for your help,
V/r, bw
Posted by Anonymous on Friday, December 19, 2003 12:13 PM
I am admitedly a novice, but I'm currently using FLAT toothpicks. If the burnishing is done carefully & evenly it will add a little luster to the foil (at least it did on my 1:144 B-29). BE CAREFUL! Using the flat toothpicks can easily rip the foil when burnishing, and if not done evenly will look like metal has been "scraped". Hope this helps, I had a helluva time with Bare Metal Foil, but it really does look good when done properly.
Bill Howe,
www.444thbg.org
    December 2003
Posted by scottrc on Friday, December 19, 2003 1:20 PM
Art stores sell a soft wood Burnishing Tool. This tool has a flat side, round side, and has a geometric shape at the opposite end. It is designed for many types of foils and acrylics. I use mine to death since I'm a Rub -n-Buff fanatic and use a lot of gold and copper foils that I rub out to change the hue. These tools are easy to make out of Basewood.
I also still use toothpaste as a polishing agent. Kinda old remedy but is cheap and plentyful.
    November 2003
Posted by shrikes on Friday, December 19, 2003 1:25 PM
Do you have a link to what one of these things looks like? I'm about to start an F-86F that i'm going to apply bare metal foil to...
Toothpaste will polish bare metal foil? how do you get it to shine? is this something i want to do on an airplane?
Sorry about all the questions. Big Smile [:D]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
