update: F-104 New project
Posted by chasblake99 on Saturday, November 15, 2003 11:52 PM
I’m starting a Hasegawa 1/32 F-104. I plan on doing the fuselage in foil and I’m getting a new ejection seat from CAM. Does anybody know where I can get the KMC detail set for the interior? I'm also looking into alternate decals, any suggestions?
Update:
While waiting for the cockpit from blackbox, the foil is going on quite nicely.
I've dicided to mount it flying and need some info. DId F-104 pilots have a seat parachute or a back pack style with a seat survival Kit?
Thanks for the help.
Charles  NKAWTG (My KC-135R at RAF Fairfird during Allied Force) Pilots without crew chiefs are nothing but pedestrians with nice sunglasses and a cool jacket. Crew Chiefs RULE!
Posted by Butz on Sunday, November 16, 2003 3:23 PM
Hey chas,
Either check w/ Verlinden or Cutting Edge(www.meteorprod.com). Ya know I think(I said I think) that Black Box may also have a reesin interior for the 104 as well?
Please keep us posted w/ updates on your projectWink [;)]
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
Posted by chasblake99 on Sunday, November 16, 2003 5:51 PM
Thanks for the heads up on the Blackbox kit. I checked and CE makes a beautiful set but only in 48th. Too bad.
Posted by J-Hulk on Friday, November 21, 2003 7:54 AM
Charles, how is that kit, anyway? I see 'em on the shelves here all the time, and have come very close to picking one up several times. They sure are cheap enough! About 30 bucks, US.
~Brian
Posted by berny13 on Friday, November 21, 2003 10:45 AM
F-104 pilots had the back pack chutes. It was not kept with the aircraft and each pilot had his own. The seat contained the survival kit which stayed in the aircraft.
Berny
 Phormer Phantom Phixer
On the bench
Posted by chasblake99 on Friday, November 21, 2003 12:40 PM
Berny13
Thought so, but wasn't sure. Thanks, I'm using a pilot from a newer kit and have to add the back pack parachute so he'll sit in the seat better.
Big J
The kit is not bad, just old. The instrument panel is pretty good, the seat is terrible. Exterior shape is good as is the engine and landing gear. Only drawback is raised detail but that looks prettty good witht the foil. Got to looking in my collection and I have three others. On the next one I'll go for recessed panel lines
Posted by J-Hulk on Friday, November 21, 2003 7:18 PM
Thanks for the info, Charles.
~Brian
Posted by chasblake99 on Friday, November 21, 2003 10:23 PM
Solved the parachute problem. I used a Tamiya pilot and cut the chute off the Hasagawa one in the kit. If you seperate the back of the head and cut at the bottom of the chute it'll fit nicely on the new pilot. Fill the sides with putty and paint.
The Hasagawa pilot was only suited for use as spare parts. I'll post a picture if I ever get it figured out.
Posted by rangerj on Sunday, November 30, 2003 4:26 PM
berny13,
I remember reading somewhere that ejection from an F-104 was downward in order to avoid hitting the stabilator. Further, the early variants used an ejection seat made by Lockheed. Did the F-104 ever get an upward fireing "zero-zero" ejection seat?
Any F-104 lover,
I have been wanting to do a CF 104 (CANADIAN) IN THE BRIGHT RED with the white arrow that runs the length of the fusilage. I would be grateful if anyone could tell me which variant was used for this aircraft. Was it a "C" or a "G" as far as the fuselage and flying surface dimentions are concerned. I have not been able to find a Federal Standard Color reference for the red either. Do the Canadians have such a standard color reference chart? Any information would be apreciated.
Lastly, you want to look into the F-104 pilot's high altitude pressure suit and helmet if you are doing an F-104 from it's early years. Let us know how the foil job goes. rangerj
Posted by berny13 on Sunday, November 30, 2003 4:38 PM
The F-104A and B models were the only ones that used the downward firing ejection seats. The F-104 was the second (F-106 was first) aircraft to be equiped with rocket assisted ejection seats. The A & B models were later modified with the rocket ejections seats.
The old style catapult ejection seats were not powerful enough to propel the seat past the stabilizer in a high speed ejection. Once the rocket seat was perfected, all front line aircraft were modified with rocket powered seats.
Now you know the rest of the story.
Berny
On the bench
Posted by chasblake99 on Monday, December 1, 2003 3:16 AM
rangerJ
For the pilot I decided on a late sixties/eari;y seventies orange flight suit and same era harness colors.
The foil is going on well execpt for the large flat surfaces (wings and stab) Seem to always catch dust under the foil but I'm still working on it.
I think our neighbors to the North had the CF-104. It was basically similar to the F-104G, but was fitted with equipment specialized for RCAF requirements. It differed from the F-104G in being optimized for the nuclear strike role rather than being a multi-mission aircraft. It had other differences as noted on this site:
http://home.att.net/~jbaugher1/f104_27.html
Lots of good info on that site
