Soviet buzz numbers
Soviet buzz numbers
Posted by Anonymous on Monday, November 17, 2003 12:39 AM
Do these things have a purpose? I know that soviet ships used temporary hull numbers (unlike us ships). Is this the same idea?
Btw, what about USAF buzz numbers from the '50's?
Posted by berny13 on Monday, November 17, 2003 10:58 AM
Buzz numbers were placed on USAF aircraft in the late 40's. This way it would be easy to record the number of an aircraft that flew under a bridge or buzzed a town. In 1963/'64 time frame buzz numbers were removed because it was found that someone sitting on a hill top or parked on a road could record the serial numbers of all aircraft assigned at a base. They would be able to have an accurate account of the aircraft and the amount that each aircraft flew. It would also give them an idea of mission capable aircraft at a base.
Over seas bases were the first to remove the buzz numbers, followed by TAC and SAC but ATC (allergic to combat) bases kept their buzz numbers longer. Something about not trusting student pilots.
Berny
 Phormer Phantom Phixer
On the bench
