Anti-static tubes
Anti-static tubes
Posted by Bones-coa on Wednesday, November 19, 2003 9:36 PM
I know I somewhat ask this question ahwile back, but I didn't get alot of answers. I have some wire to reproduce anti-static tubes. In my case, the end of the tube has a nozzle or "tip"on it. How do you guys reproduce this tip?
I've tried epoxy, CA, plastic sprue...all do ok but it's difficult to get them in the right shape and even porportions. Especially when you've done 10, and relize all 10 look different.
Any ideas on this? Thanks.
Dana F
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by berny13 on Wednesday, November 19, 2003 11:42 PM
Are you talking about the static dischargers found on the trailing edge of wings, tail etc? If so there were several types used by different aircraft. What are you building? Give a little more information and I might be able to help.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Bones-coa on Thursday, November 20, 2003 5:50 AM
The aircraft is a Mig-29. The tubes are flared at the ends looking a bit like a funnel or nozzle. If need be, I can hunt down a pic for ya.
Dana F
Posted by berny13 on Thursday, November 20, 2003 9:50 AM
It sounds like you are asking about static dischargers. Which version are you building and what scale?
Berny
On the bench
Posted by Bones-coa on Thursday, November 20, 2003 10:38 AM
I am. It's the 1/32 version put out my Revell some time ago. Not the current Revell Gewrmany one. Although I think the model itself is the same. Just reboxed.
Posted by Anonymous on Thursday, November 20, 2003 11:22 AM
Do you mean the Odd Rod IFF system found on most modern ish migs?
Posted by Bones-coa on Thursday, November 20, 2003 11:31 AM
No, these are static tubes. The Mig-29 has one on each verticle stabilizer and two on each wing.
Posted by berny13 on Thursday, November 20, 2003 11:39 AM
Artificial Feel Force Pickup Probes. Now I know what you are talking about. Let me do a little research and get a close up picture of them and I'll get back with you.
Berny
On the bench
    October 2003
Posted by sharkbait on Thursday, November 20, 2003 11:54 AM
Artificial Feel Force Pickup Probes - LOL - I love it! Can I get some to use the next time I get to a Bar???
Name kinda speaks for itself.
Often wondered what those were - didn't look like static wicks. Learn something new every day!Smile [:)]
You have never been lost until you've been lost at Mach 3!
Posted by Bones-coa on Thursday, November 20, 2003 12:44 PM
Here ya go:
Posted by berny13 on Thursday, November 20, 2003 3:39 PM
Those items on the trailing edge are static dischargers. You can build them out of stretched sprue. The tips were aluminum caps with fine wire dischargers attatched.
The artificial feel force pickup probes were located just aft of the leading edge about 4/5 way down. It consisted of two probes bent at a 90 degree angle with the opening facing forward. You can just see them in the photograph.
Berny
On the bench
Posted by Bones-coa on Thursday, November 20, 2003 6:00 PM
Maybe I'm just not good with streching sprue yet, but if I did that, I'd have 10 that were different diameters. That's the reason I went with the wire. However I didn't even consider the ends at the time.
Is there a trick to sprue stretching to make it all the same size?
Posted by berny13 on Friday, November 21, 2003 9:50 AM
Try Evergreen Plastics. They make pre formed sprue in various thickness you can use. It would work great for the scale you are building.
Berny
On the bench
