Fuzzy - the engine is plastic, and it is very highly detailed. Its made from 35 parts, excluding engine bearers & canon.
The fit of the 262 appears to be about the same. In other words, careful assembly & dry fitting is necessary. I would definately recommend the Trimaster kit. White metal cannons, nose weight, and 2 frets of p.e. And for $30, it can't be beat. The quality of the moldings and the plastic are superb. The panel lines are consistent & subtle. With a wash, it won't look like a jigsaw puzzle.
Chris - I ordered the Mistel & Ta 152 from Great Models. THe Mistel was $31.20, and the Ta 152 was $24. Both bargains, as far as I'm concerned.
John - Unlike the Italeri kit, you get the engine, which I'm sure you know is visible from the open wheelwells. The only problem is finding decals for this kit. The DML decals that I've used have yellowed with time. Aftermarket FW 190D stencil decals will work, but getting info on the net for individual aircraft is scant. Jeff Ethell did a Monogram (I believe) book, which is OOP. All I've found are profiles, which tell nothing about the wing camo.
I'm glad to see some interest in these kits. The Trimaster/DML/Dragon kits are my favorites, above Hasegawa & Tamiya.
