I spent the afternoon wandering around the airport. There are 3 amphibs here. Got some ideas, took some pictures, made a few stencils. I think I can pull this off.
We don't have the resources/ability to build a scale model and wind tunnel test it. So we're going to use science, math, and fabricating sense to build it.
The intitial plans go off to John tomorrow. Basically I'm going to use aluminum tube (DOM) to build a framework and then skin it. I'm thinking 12 gauge aluminum on the bottom since that has to take the impact of the plane hitting the water. The sides I'll likely skin in 16 gauge aluminum and the top will be 22 gauge. This should keep the weight down to a manageable level. I hope. For mounts for hydraulics I will likely use 1/2" aluminum plate triangulated into the frame.
Right now the big debate is rivets versus TIG'ing the skins. Fred says TIG welding wasn't invented until the 1960's so the skins on the floats would have been riveted or gas welded. I'd like to TIG everything possible because I know it will be stronger and more watertight than riveting. Even though it won't be period correct. My contention is it will be safer, stronger, and lighter than riveting.
The rudders are another source of debate. I think the best way to do the rudders on the floats would be an electric over hydraulic system. Have a hydraulic system in each float electrically controlled from the cockpit. Fred wants to tie it in to the planes hydraulic system.
The landing gear hydraulics are a real ball buster. I'm not an aircraft mechanic so I'll have to leve that up to Mike and Fred. Apparently to get the front struts to swing out and down requires custom pieces. Mike thinks he can modify something off a Piper to work but isn't sure it can take the weight. If not we'll be spending some serious time in the machine shop.
It's not a walk in the park, but I think we'll be able to work through it. Thanks for posting that link. I had no idea one of these aircraft was still around. I must try to look at it personally.
