Paint on bare metal?
Posted by lpolpo22 on Saturday, December 6, 2003 4:43 PM
How do I prep Bare Metal Foil for painting? Can it be masked?
Posted by Ashley on Saturday, December 6, 2003 5:18 PM
You have to treat it like a real airplane, in other words, you are not painting plastic anymore, it's aluminum! It can be masked if it has been well burnished to the model and a low-tack mask is used and carefully removed. Prime the foil with a self-etching primer that you can get at the hardware store. It is sold as self-etching or aluminum etching primer. Then, your color coats will stick!
Have you flown a Ford lately?
Posted by lpolpo22 on Saturday, December 6, 2003 7:30 PM
Thanks Ashley, I'm off to the hardware store as soon as the snow melts. will self-etching primer damage any plastic it may come in contact with?
Posted by Ashley on Monday, December 8, 2003 8:11 AM
You know, I've never tried it on plastic! I have always had the entire model foiled, and I carefully masked the whole model when I did this. I worked out this technique originally to make canopy frames. I buff household foil with a Scotchbrite pad and cleah it with alcohol, then prime it with the self etching primer. Then I'll paint one side the exterior color, and the other the interior color, Then I cut it in strips and apply them to the canopy with foil adhesive.
    November 2003
Posted by shrikes on Monday, December 8, 2003 1:16 PM
Aluminum Etching Primer? Are you sure hardware stores will sell this (I live in the Philippines)? it wouldn't be a clear primer would it? What happens if i want to wash the model? and where do you get foil adhesive? sorry for all the questions...
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
Posted by Ashley on Monday, December 8, 2003 8:59 PM
Oooh, the Philippines. I don't know if it would be carried there, but it should be. The primer is essentially zinc chromate. I have seen it called self-etching primer, zinc yellow primer and aluminum etching primer. The can should state that it is formulated for aluminum.
By washing the model, I assume you mean a color wash to accent the panel lines? Once it is painted, you can use washes, dry-brushing and other weathering techniques as normal!
Micro-Mark makes a foil adhesive, they call it Micro Metal Foil Adhesive, and it is essentially a contact type cement. You brush it on, allow it to "dry", and then burnish the foil in place. It is a good alternative to Bare-Metal foil, especially if you can get Nestle's Crunch candy bars. They are wrapped in a highly reflective, extremely thin foil that makes great landing gear strut oleos!
