Seam lines in F-15 intakes
Posted by MikeV on Sunday, December 7, 2003 1:23 PM
What do you people who have built the 1/48 F-15E kits do for the unsightly seam that is visible in the air intakes? They have to be painted white and then the two halves are glued together leaving a seam. I could put the red covers over the intakes when finished to hide them I guess.
Any ideas?
Thanks
Posted by Anonymous on Sunday, December 7, 2003 3:32 PM
Try here...
http://www.f-15estrikeeagle.com/
Posted by MikeV on Sunday, December 7, 2003 5:25 PM
QUOTE: Originally posted by hou_ge2000
Try here...
Thanks hou_ge2000.
I had that link in my favorites already. Wink [;)]
Posted by caine on Sunday, December 7, 2003 7:07 PM
You know I just saw something that might help with that in one of the FSM tips. Try that ink correction tape you buy at the office supply stores... you know like white out. That could nicely cover a small seam and it is white, so no painting required (as long as the intake is white in both sections.
http://www.shockwavephoto.com
Posted by Anonymous on Monday, December 8, 2003 9:31 AM
Another thing that works good is model cement although it requires some sanding and you have to be carfeul not to sand out the lines on it
Posted by berny13 on Monday, December 8, 2003 9:47 AM
The trick I have used is wood dowels of different dia. Just glue sandpaper to the dowel and use light sanding pressure. Finish up with wet sanding with the dowel and sandpaper. Repaint and go from there.
Berny
 Phormer Phantom Phixer
On the bench
Posted by MikeV on Monday, December 8, 2003 6:34 PM
Thanks for the tips guys.
I wish Revell had just made these intakes one piece. Big Smile [:D]
It should be fun trying to paint the inside white again with the two halves glued together.
    March 2004
Posted by Mikeym_us on Tuesday, March 30, 2004 7:16 PM
did you try to use a seam scraper
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
Posted by maddafinga on Tuesday, March 30, 2004 7:35 PM
Hey Mike, I got a Seamless Suckers exhaust intake for my A7-E. It looks very good and has no seams whatsoever. I think I've still got their address and price list if you want it. It's going to require a bit of dry fitting, but not to much I don't think, so it's going to be nice. They do make an F-15 intake.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by MikeV on Tuesday, March 30, 2004 7:38 PM
Thanks Josh but I already finished and installed them. Wink [;)]
    May 2015
Posted by willuride on Tuesday, March 30, 2004 8:30 PM
hey maddafinga,
i'll take that site if you're willing to part with it. You can sendit to willuride@yahoo.com
thanks.
On the bench Knoxville, TN:
1/48 Monogram F-4 Phantom "Black Bunny"  I wanted to relive the past....Never again
On the Bench Manchester, TN:
1/48 Revell F-18E
