- Member since
Posted by Swanny
on Monday, December 8, 2003 8:41 AM
Did you get just one or is there a second canopy also? If there are two then you have some room to make a mistake. Trim the excess material away from the canopy leaving a small amount behind then use a fingernail file to sand away the remainder. Be careful not to scratch the canopy or tear the material. Test fit several times as you sand it to ensure the fit is correct. When it has been trimmed up all the way dip it in Future and set aside overnight to cure. Be sure to place it on a piece of tissue paper and cover it with a cup to prevent dust from settling on it. Attach to the model using Elmer’s white glue, Testors clear parts cement or watch cement "crystal clear".
