I need tips for painting round insignias
Posted by Anonymous on Monday, December 8, 2003 12:49 PM
I need tips for painting British rounded insignias. Any contribution is more than welcome.....
So far my job has been sloppy... please help
thanks in advanced....
Posted by cassibill on Monday, December 8, 2003 1:32 PM
If you can't use decals-Try a circle template. Start outside and work inside. The outer edges of the next circle may require a little more work to cover the prvious color but that should work..
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
    June 2003
Posted by garys on Monday, December 8, 2003 1:53 PM
Try copying your roundel ontp frisket film, then use that as your stencel, repeat for different diameters. The film sticks saw there should be no overspray. HTH
Posted by Anonymous on Monday, December 8, 2003 4:03 PM
Sign - Ditto [#ditto] I do a lot of RAF WWII AC and have found the circle template drafting tools from HS come in quite handy for this.....most have every size circle from just big enough to stick a pencil lead into all the way up to 2"....
Posted by BlackWolf3945 on Monday, December 8, 2003 10:06 PM
You can use several things to cut the masks themselves. I've got a buncha punch & die tools which I've used to make roundels in combination with post-it tape and also what's known as transfer tape.
If you haven't got any punch and die tools, get some varying sizes of brass tubing and use an X-Acto to trim away either the inner or outer edge of each tube (finishing off with sandpaper or files to even it out) until you get a nice sharp cutting tool.
Anyhoo, I'll get all my measurements worked out in advance (however you choose to do this is up to you) and cut several sets of masks as backups.
This is not to scale...
Gray represents a mask or masks.
1 I'll use the female outer mask, positioning it correctly, and then spray red.
2 I'll then place the male outer mask with a section punched out leaving the area to be sprayed white uncovered; I'll also place a mask covering the inner red circle.
3 After spraying the white, I'll remove the inner masks, leaving the female outer mask; this is the result.
4 I'll then place a mask over the white and red and spray blue.
5 Removing all the masks, this is the result.
For roundels with the yellow surround, or for the two-color roundels, adjust accordingly. The only other roundels I've done using this technique are Aussie, but you can use it for virtually any roundel you can think of.
Some may find this difficult, but it's EZ for me; and fairly quick. Any questions, give a hollar.
Fade to Black...
Posted by Anonymous on Tuesday, December 9, 2003 12:44 AM
WOW Ill have to give that method a try it does seem rather complicated but I think the end results will be better! Thanks for sharing the detailed method!
Posted by Anonymous on Tuesday, December 9, 2003 4:33 AM
use a bloody decal....!!!!....lol.
Posted by Anonymous on Wednesday, December 10, 2003 5:36 PM
I like kitbashed's idea, but go from lightest to dakest color to keep from having dark colors show through the white.
