How to do in-flight models with plastic rods?
Posted by Anonymous on Monday, December 8, 2003 1:30 PM
I'm looking into making a stand that will hold an in-flight model airplane, and I want to use a plastic rod that curves from the base to the airplane. The rod will go in at a 45 degree angle into the base and then curve around like a "C". The top portion will have scratch built clamps, so you can remove the aircraft.
Now here is the question... what kind of plastic rod should I use? Acrylic, Polyurethane, Polystyrene, Polyethylene? I need to be able to heat it up with lighter or something, so I can bend the rod easily.
Here are some that I found:
Acrylic:
http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&category%5Fname=Acrylic&product%5Fid=Clear+Extruded+Acrylic+Rod
Polyurethane:
http://www.usplastic.com/catalog/category.asp?catalog%5Fname=USPlastic&category%5Fname=Polyurethane&Page=1
Polyethylene:
http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&category%5Fname=Polypropylene&product%5Fid=Low+and+High+Density+Polyethylene+And+Polypropylene+Rod+Stock
Polystyrene: http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&category%5Fname=Styrene&product%5Fid=High+Impact+Polystyrene+Tubing+And+Rod
Posted by ckfredrickson on Monday, December 8, 2003 3:44 PM
From the resources I've seen go with the acrylic. See the link for how to form it.
http://www.aircraftresourcecenter.com/tnt1/101-200/tnt106_DisplayStand_Chung/tnt106.htm
Posted by Anonymous on Monday, December 8, 2003 5:13 PM
Thanks much!! I think I will order several rods from this place
http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&category%5Fname=Acrylic&product%5Fid=clear+Extruded+Acrylic+Rod
