To foil or not to foil...
Posted by Anonymous on Tuesday, December 16, 2003 9:29 PM
Blush [:I] Just a small amount of confusion...I'm using Cutting Edge Modelworks Bf 109G-6 cockpit (which I highly recomend). It states that I should use foil for the retaining straps on the footpedals. What kind of foil is it?
I have noticed that some used lead foil...is that it & where would I acquire it? Any help is greatly appreciated.
Keith
Posted by Anonymous on Tuesday, December 16, 2003 9:45 PM
I took this foil from a champagne bottle. You can also find it on bottles of regular wine.
This is the Verlinden set for the Bf 109G-2.
Hope this helps.
Posted by Anonymous on Tuesday, December 16, 2003 9:49 PM
Unfortunately not a wine drinker....anywhere else?Confused [%-)]
    May 2003
Posted by obiwan on Wednesday, December 17, 2003 12:00 AM
you can find it anywhere....
the foil covering on milk powders cocoa etc.. tins.
in the uk on the covers of chinese take aways...not a wine drinker?go to
a local pub/restaurant and explain your problem to the cute waitress.
look in hardware shops for alluminium tape
if not you'll be foiled again. sorry couldn't resist.
ps; as an alternative to foil you can use tamiya masking tape.and
if you use the tape it would stick on by itself.
What baby wants baby gets
Posted by Anonymous on Wednesday, December 17, 2003 12:06 AM
You could also use heavy-duty kitchen aluminum foil I would assume, get a roll cut of the size you need and attach it.
Posted by Anonymous on Wednesday, December 17, 2003 3:05 PM
Thanks...this is good information.
Oh and Obiwan...nice pun!Laugh [(-D]
Posted by Anonymous on Wednesday, December 17, 2003 4:02 PM
I have found the metal tape (aluminum I think) used to seal air conditioning and heating ducts (HVAC section of Home Depot) to be excellent. It is adhesive backed and slightly thicker than Bare-Metal foil (makes it stiffer). One roll will last a lifetime.
