Gluing the plane together
Posted by Anonymous on Thursday, December 18, 2003 9:39 AM
I am pretty sure I know the answer to this question, but I want to ask anyway.
After you have glued one side of a cockpit into a plane, do you glue on the other side and then work on the seam?
I have this V22 Osprey. (Italeri 1/48th scale). My brain got stuck. How do I glue the cockpit in place without gluing both sides of the plane together.
So now I am thinking that I have to glue just the ramp and cockpit, with no glue on the fuselage seam.
After that's dry I would then go about prying the seam around the plane and gluing sections of the fuselage together.
Is this how you guys do it?
Small fighter planes might be easier because you can glue the cockpit and work on a seam area at the same time, but I have this cargo plane.
Posted by rjkplasticmod on Thursday, December 18, 2003 9:53 AM
On the majority of my builds, I only glue the cockpit interior to one side of the fuselage, after dry fitting to make sure it fits ok and doesn't interfere with the fuselage halves mating. Usually use Super Glue for interiors to fuselage. When dry, assemble the fuselage halves. Have'nt built the Italeri Osprey so you may have some unique problem, but your plan sounds pretty high risk.
Rick
Posted by J-Hulk on Thursday, December 18, 2003 9:55 AM
Not quite sure how the V-22 goes together, but here's what I do on all sizes of aircraft:
I glue all the interior pieces (cockpit, cargo bay, bomb bay, whatever) into one fuselage side, dryfitting the other fuselage side all the while to make sure all the interior components are properly aligned.
After finishing up all the interior painting, I then glue on the other fuselage side.
Is that what you were asking about?
~Brian
Posted by J-Hulk on Thursday, December 18, 2003 9:56 AM
Rick, you're quick!
We simulposted!
~Brian
Posted by Anonymous on Thursday, December 18, 2003 11:25 AM
Usually cockpit to fuselage then join the fuselage halves.
If there is enough room I use a paintbrush with liquid cement and glue the other side through the open cockpit - carefully
    November 2003
Posted by shrikes on Thursday, December 18, 2003 12:51 PM
What i used to do as a kid was to just glue everything on at once. it usually ended roup a godawful mess... What i've found that works is that you should glue the cockpit to one side of the fuselage and then dryfit the other half to make sure that the seams are okay. Use a rubber band around the fusalage to make sure that the fusalage halves stay together while the glue on fuselage half and the cockpit is drying. I repeat the process for other sections... (if on a B-17, the bombardier/navigator's cabin, the cockpit, the bomb bay, the radio room, the waist section) It's on;y after everything that should go in is there (i.e. turrets, windows, interiors, etc...) is glued down tight, that i assemble the fuselage halves. of course, even then seams can still be a problem.
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
