Brass tubeing for struts?
Posted by Anonymous on Friday, December 26, 2003 12:55 PM
Hi all,
I was wondering if any of you have used metal tubeing to rebuild the struts of your A/C. I have heard that for the bigger 1/48 scale A/C that sometimes the weight of the model will bend or break the plastic struts. Has this happened to any of you and if so, which kits? I have several 1/48 scale kits and would hate to put them together just to have them not able to support their own weight.
Thanks for any info and help Smile [:)]
Posted by Anonymous on Friday, December 26, 2003 1:00 PM
Not being able to support their own weight?...That's urban legend...lol
The thing with brass tube is a bit of fashion and personal liking.....
Tried them once couldn't tell that I was majestically thrilled.
See for yourself.
Posted by toadwbg on Friday, December 26, 2003 1:20 PM
I've seen this on various people's scratchbuilt stuff. Works great in theory if you can scratchbuild it.
Try this on some scrap landing gear.
- Get Brass tubing or rod of the right diameter
- Drill out the inside of your plastic landing gear. The difficulty here is drilling a concentric hole to the existing landing gear.
- Insert stiffening rod, fuse with superglue
Alternatively, you can just drill a tiny diameter hole and use finer wire for strengthening.
"I love modeling- it keeps me in the cool, dark, and damp basement where I belong" Current Projects: 1/48th Hasegawa F-14D- 25% 1/48th Tamiya Spitfire- 25%
    May 2003
Posted by qmiester on Friday, December 26, 2003 1:23 PM
I have yet to use brass for interplane struts, prefering to use styrene there. But I have used brass several times for replacement struts in landing gear assemblies. You can get both brass (Strutz) and styrene (Contrail) from Roll Models.com. (The brass units are a heck of a lot more expensive)
Quincy
Posted by Melgyver on Friday, December 26, 2003 2:31 PM
I once made a set for Airfix's old 1/24th scale P-51 because I wanted working oleo struts. Came out pretty good except I didn't make brass scissors and the plastic ones broke. Never got around to making brass scissors. I used the springs from the bomb release part of Monogram's old 1/32nd P-51 kit for the struts inside the brass tubing. I think Trumpeter has working struts on thier 1/24th kit except it's all plastic. Usually the weakest part is the curved fork on nose or tail wheels. The struts are usually more than strong enough.
Clear Left!
Mel
Posted by rangerj on Friday, December 26, 2003 7:01 PM
You can stiffen the landing gear legs with piano wire, the stuff used for flying models. It is very stiff and difficult to cut or bend.
The difficulty is drilling straight and deep enough. The chromed brass tubing works well for oleo legs, and it comes in a wide variety of sizes. Again it should be easy to find at a shop that sells flying models, or rail road supplies. rangerj
