Discolored Aluminum: Heat
Posted by Bones-coa on Thursday, January 8, 2004 11:20 AM
Guys, in trying to finish this NMF Mig-19, the exhaust section does not have steel, titanium, etc like other aircraft. Instead that section is aluminum. According to photos, this area discolors. I'm painting this aircraft with buffing MM aluminum. How can I reproduce this effect? Thanks.
Dana F
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by Anonymous on Thursday, January 8, 2004 1:20 PM
Revell do a clear Gold paint (Revell Germany, Klar 730). Try thinning a few drops of this down (very thin!) and almost 'dry brush' it on.
If it's not thin enough it just looks sort of goldy/brown (my F-100 is testimony)
E
Posted by Anonymous on Thursday, January 8, 2004 1:56 PM
I tried a burnt metal technique using a couple of shades of Alcad and it came out pretty good on my first half-hearted try. It surprised me enough that I was disappointed that I didn't take it more seriously.
Posted by cmtaylor on Thursday, January 8, 2004 2:06 PM
Alternatively, take some aluminium foil, put it in a pan of water, then boil it up with some broken egg shells. The foil changes colour quite convincingly
Gentlemen! You can't fight in here; this is the WAR ROOM!
Posted by rjkplasticmod on Thursday, January 8, 2004 3:17 PM
Since your'e using Model Master paints you might try their "Jet Exhaust ", thinned down and lightly sprayed until you get the effect you want. It's a brownish gold metallic that represents the heat staining pretty well.
Rick
    October 2003
Posted by A. Howard on Thursday, January 8, 2004 6:32 PM
If it's a goldish-yellowish look you want, you could try a technique I discovered while painting a WWI rotary engine. Paint an aluminum base coat, then take a jar of MM Turn signal amber which has settled, so that all the flakes are in the bottom, dip a brush into the tinted carrier at the top, and dab it on. After it's dry, overcoat with the proper sheen of clear, and it should look quite convincing.
Posted by Bones-coa on Friday, January 9, 2004 6:55 AM
Thanks guys. I think I'll just try all of them on some scrap and see what turns out best. Thanks again!
Posted by maddafinga on Friday, January 9, 2004 7:01 PM
Keep us posted Dana, I'm pretty interested to see how this comes out. That has been an effect that has always impressed me, but I've no idea how to achieve it.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
