Resin is a totally different member of the plastic family from the typical styrene of injection molded kits.
Resin is very much like two part epoxy glue, it has two components, the resin and a catalyst to harden it. and is molded by pouring it while its in liquid form into rubber molds.
Resin is a very typical material in limited run, "garage kits" which are made and sold by smaller firms or private individuals who do not have the money to invest in metal mold tooling and injection plastic molding equipment.
So, the differences:
1: glue for styrene plastic has no effect at all on resin, you'll need two part epoxy or cyanoacrylate glue (Krazy Glue) to get them together.
2: The quality of resin castings can vary significantly from manufacturer to manufacturer to a much greater degree than the molding quality of styrene in more mainstream kits does. Air bubbles are not an unusual thing in resin kits, some manufacturers go to great lengths to minimise bubbles, one way some of them do it is to put the molds in a centrifuge and spin them while the resin sets up, this uses the force of gravity to work the bubbles out.
3: ALWAYS expect to pay more for resin kits than you would for styrene, this is not a reflection of superior quality in the resin over styren, but more a reflection of the limited run nature of resin kits, as they are not mass produced, their manufacturers must charge more to recover costs and make a profit.
4: some resin tends to shrink or warp over time (this is why I prefer not to buy full resin kits) Resin aftermarket accesories for styrene kits usually don't present any problems this way, but full resin kits canbe a different animal completely.
Hope that helps
