Please read and respond if you have the 1:48 Hasegawa stuka, JU87B2. A fellow modeler was very gracious and faxed me directions for the G2 version. Doesn't help. I lost the directions. Here is the question.
The prop has three blades which fit into a spinner. I do not know if this spinner attaches directly to the fuselage nose or if there is an additional piece. The reason is, the back of the prop spinner has a piece which is not flush in the4 center. The spinner does not fit flush on the nose. I assume there is an additional plate which I must have also misplaced. I can do some sanding and try to get a fit but before I do that, I want to make sure if I am missing anything.
So, of you have done the Hasegawa Stuka 87B2, please look at it or please fax me the directions at 859-257-9608. Thank you! i AM SO CLOSE TO FINISHING THIS PLANE. iT IS SITTING IN LIMBO WAITING FOR FINAL PREP.
