Original paint schemes
Posted by Anonymous on Thursday, January 15, 2004 5:12 PM
Hey, i'm new to this site and new to modeling in general. It's been at least 6 years since my last attempt at modeling (I'm 17, going on 18) . I have always like the BF-109's and I figured that this would be the best plane to start off with (if I'm gonna build It, I might as well like it)
I've been searching around and havn't reall found any interesting paint schemes so far. most of the coolest ones are much to difficult for me to even attempt. I was wondering If anyone here hs ever just came up with their own paint schemes, or mostly just stuck to historical ones?
lmk what you think, and if you have any cool looking schemes that you think I could tackle, post em!
Posted by Anonymous on Thursday, January 15, 2004 6:01 PM
Sign - Welcome [#welcome] Welcome to the forums Graham,
Well there's definately no shortage of different schemes when it comes to the 109's! I myself prefer to keep as historically accurate as possible, but I also think that part of the fun of this hobby is the freedom it allows. If you like it that's all that's important. Some of my favorite models in the galleries are the "what if...'" models. It comes down to how you want it. Above all have fun!Big Smile [:D]
Posted by Anonymous on Thursday, January 15, 2004 6:17 PM
thanks you Adam
I was thinking maybe an all mat-black plane with white accents?
Posted by Anonymous on Thursday, January 15, 2004 9:38 PM
Many of the early war Bf 109E schemes were simple "splinter" (hard-edged, done with masks or a steady hand & brush) patterns of RLM 70 (black green), RLM 71 (dark green) and RLM 65 (light blue). These colors are widely available from many manufacturers, both acrylic & enamel. The majority of schemes at that time did not carry the "mottling" (random, soft-edged dots) seen on later war aircraft. If you choose a Bf 109E kit, it will probably have markings for at least one AC in this scheme.
Posted by Anonymous on Thursday, January 15, 2004 10:43 PM
Graham, from what I've seen on this sight Pixilater is a definate expert when it comes to WW2 german a/c's! He does GREAT work.Bow [bow]
Posted by Anonymous on Thursday, January 15, 2004 11:31 PM
Ahh..Yes.. The one-o-nine..Its a beutiful aircraft. Here is some of the forum people has done the 109's. here it is... http://az.poertner.net/%7Ejrdoll/fsm_build.htm
Check it out.
Posted by Anonymous on Thursday, January 15, 2004 11:32 PM
Hey pixilator, got pics?
    November 2003
Posted by shrikes on Thursday, January 15, 2004 11:36 PM
Uh, oh... you asked for it now... Big Smile [:D] Maybe you should specify a 109 version...
Just kidding, pix! Wink [;)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
Posted by Anonymous on Friday, January 16, 2004 2:49 AM
Years ago when I got back into modeling from a long hiatus and before I got my airbrush, I did a 109. Did most of the painting with rattle cans and it turned out surprisingly good. I sprayed the underside first. Then masked off the wings and did a splinter pattern. Masked the tail and nose and sprayed my RLM 04. For the mottling I got creative. I took an old sock, cut several random holes in it of various sizes/shapes and layed this on the model and sprayed with a few quick easy bursts. Move the sock a bit, spray, move, spray, etc. The reason I chose the sock was because a regular T shirt would get too saturated with paint and may leave streaking. With a sock ( or even an old towel) the material is thicker and not likely to get as wet. You dod need to be a little careful between moving the rag as you want the paint to dry a bit so you don't accidently smear it between repositioning. This method gave a nice mottling effect as the holes weren't directly against the fuselage and the space in between created softer edges.
The kit I did? Hasegawa's 109E in Galland markings.
Posted by Anonymous on Friday, January 16, 2004 9:29 AM
Here's some examples of early war 109s.
http://www.eaglestrikeproductions.com/cgi-bin/amddecals.pl?scale=48&setid=497&dbs=aeromaster&pgs=2&currpg=1&dclimg=ad48497
Hope this helps, & good luck on the build !
Posted by djmodels1999 on Friday, January 16, 2004 2:46 PM
Mmmm.. could try the one that Tintin flew in The Ottokar' Sceptre... Simple scheme and original national markings...!
Posted by eagle334 on Friday, January 16, 2004 3:18 PM
Graham
If you want to paint your own scheme on your own model, go for it ! Thats the great thing about this hobby, If you want to paint it as accurately as possible you can do that (its impossible to get it 100% accurate) or you can paint it as imaginatively as you want. I love "what if " schemes.
I built this X-29 as an aggressor because I thought it would look cool, and have gotten a lot of comments about it.
Just remember its a hobby and should be FUN ! If different schemes please ya, go ahead.
Wayners Go Eagles! 334th Fighter Squadron Me and my F-4E <script language="javascript" src="http://www.airfighters.com/phgid_183.js" type="text/javascript"></script>
