Here is a list of problems I had when I built the Academy 1/48 F-86F-30.
The intake trunks ( D25 & D26) did not match up and left a very bad seam inside the intakes. It was very difficult to remove.
The fuselage halves did not fit properly due to the molded in gun bay being too thick and hitting the cockpit tub. I had to file the outside of the gun bays down to get a good fit.
When the wings are installed there is a large gap where the top wings join against the fuselage. I filled that are in with plastic stock and sanded down for a smooth finish.
The panel behind the wing (C16) did not fit correctly and requirs some putty and sanding. The intake lip (C38) did not fit and will require sanding to match the fuselage cross section.
Be careful bending the nose gear forward door as mine broke and I had to glue it in the proper position.
Hope this helps you. It can be built into a very good model. I painted mine in Metalizer buffing alum and steel. I sealed with future when I was done painting.
Berny
Phormer Phantom Phixer
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
